Hello.
My ISP provides Internet VLAN (10), IPTV on a separate VLAN (20) and Landline Telephone VLAN (30) and.
In order to watch TV without problems the provided IPTV Box must be connected directly to this VLAN (20).
My current RB5009 is connected using LEOX LXT-010S-H SFP GPON Module to ISP
On VLAN 10 it has access Internet and gets my static IP, and on VLAN 20 is TV service. If I connect IPTV Box to the Internet on VLAN 20 (through the bridge where there are other devices and DHCP-server) I can’t watch any channels on it.
The connect to RB4011iGS+RM and RB4011iGS+RM works as a switch
How can I configure it to work.
any help to make configuration please
with regards
o… nobody knows anything about this?
hello olease gays
- Getting the most out of this forum by normis, MikroTik Support
- Topic is getting views but the homework just isn’t there.
- It’s just what happens absent adequate information.
Most ISP’s provide information on how to configure your own router…does your provider do that?
Can you show your config to be able to provide feedback (and sometimes a good laughter)?
/export file=anynameyoulike
Make sure tot remove serial and any other private information (like public IP).
Make that a configuration for ALL devices since there is no information about how they interact i.e. network design absent.
i just connect iptv device to mikrotik rb5008
Currently vlan20 and vlan30 are only associated with the sfp-WAN interface, there is no connection between them and any of the LAN ports.
Exactly what is required depends on the network architecture your ISP has implemented for IPTV and telephony traffic - routed or bridged.
If the IPTV is bridged, a fairly common method, all the Mikrotik interfaces have to be members of the bridge to permit the bridging, and VLANs used to separate the WAN and LAN traffic so it may be routed.
reflect your respect!
If you would like to help, then help.
The “IGMP Snooping” feature is required on Mikrotik side to work this setup correctly ( just a few device supports this ).
( simply saying: ISP side port Multicast-streams -IPTV- “redirecting” to VLANs )
https://help.mikrotik.com/docs/pages/vi … getreemode
