LHG LTE6 Antenna - IPv6 Problem (Not Receiving Address)
Hi guys,
about a week ago I received our brandnew LHG LTE6 kit (RBLHGR&R11e-LTE6), which is working fine with a regular data plan/SIM card - it gets the IPv4 address - with passthrough mode it forwards the address to the NIC - awesome.
While this is fine, the ultimate goal is an IPv6 connection - I have a SIM card here with an activated static IPv6 address (confirmed working with an iPhone this morning). But when I put it in the LHG with the correct APN, it does not get the static IPv6. I activated the log, but I really dont understand what is happening there:
0:12:22 lte,async lte1: rcvd *MRD_SN:AE3903CA2DD6
00:12:22 lte,async lte1: sent AT+CPIN?
00:12:22 lte,async lte1: rcvd +CPIN: READY
00:12:26 lte,async lte1: sent AT+CPMS="SM","SM","SM"
00:12:26 lte,async lte1: rcvd +CPMS: 4,20,4,20,4,20
00:12:26 lte,async lte1: sent AT+CFUN?
00:12:26 lte,async lte1: rcvd +CFUN: 4
00:12:26 lte,async lte1: sent AT*ICCID?
00:12:26 lte,async lte1: rcvd *ICCID: 89490200001548992489
00:12:26 lte,async lte1: sent AT+CNUM
00:12:26 lte,async lte1: rcvd +CNUM: "","+4915110929287",145
00:12:26 lte,async lte1: sent AT+CIMI
00:12:26 lte,async lte1: rcvd 262011702935194
00:12:26 lte,async lte1: sent AT+CPIN?
00:12:26 lte,async lte1: rcvd +CPIN: READY
00:12:26 lte,async lte1: sent AT*BAND?
00:12:26 lte,async lte1: rcvd *BAND: 15, 10, 147, 480, 50923735, 0, 2, 2, 0
00:12:26 lte,async lte1: sent AT*BAND=15,78,147,480,50923735,0,2,0
00:12:26 lte,async lte1: rcvd OK
00:12:26 lte,async lte1: sent AT*lteband=3,7,1,20,12,17,2,25,26,5,8,38,41,40,39
00:12:27 lte,async lte1: sent AT+ZGDCONT=5,"IP","festip.telekom",0
00:12:27 lte,async lte1: rcvd OK
00:12:27 lte,async lte1: sent AT+ZGPCOAUTH=5,"","",0
00:12:27 lte,async lte1: sent AT+COPS=0
00:12:27 lte,async,event lte1: *RADIOPOWER: 0
00:12:27 lte,async lte1: sent AT+COPS=3,0
00:12:27 lte,async,event lte1: +CPAS: 2
00:12:27 lte,async,event lte1: *RADIOPOWER: 1
00:12:27 lte,async lte1: sent AT+CFUN=1
00:12:27 lte,debug lte1: config ok
00:12:27 lte,async,raw lte1: sent AT+CFUN?
00:12:27 lte,async,raw lte1: rcvd +CFUN: 1
00:12:28 lte,async,event lte1: +CNEC_ESM: 30,
00:12:28 lte,async,raw lte1: +CGREG: 0
00:12:28 lte,async,raw lte1: +CEREG: 0
00:12:39 lte,async,event lte1: +CNEC_GSM: 30,
00:12:50 lte,async,event lte1: +CNEC_GSM: 30,
00:13:01 lte,async,event lte1: +CNEC_GSM: 30,
00:13:12 lte,async,event lte1: +CNEC_GSM: 30,
00:13:12 lte,async,raw lte1: +CGREG: 0
00:13:12 lte,async,raw lte1: +CEREG: 3,"5dd5","01bbe105",7
00:13:12 lte,async,event lte1: +CNEMIU: 0
00:13:12 lte,async,event lte1: +CNEMS1: 1
00:13:12 lte,async,raw lte1: +CREG: 3,"5dd5","01bbe105",7
00:13:12 lte,async,raw lte1: $CREG: 3,"5dd5","01bbe105",7,"026"
00:13:17 lte,async,event lte1: +CNEMIU: 0
00:13:17 lte,async,event lte1: +CNEMS1: 1
00:13:43 lte,async,raw lte1: +CGREG: 0
00:13:43 lte,async,raw lte1: +CEREG: 0
00:13:43 lte,async,event lte1: +CPAS: 0
00:13:43 lte,async,raw lte1: +CREG: 1,"10b9","005e834c",2
00:13:43 lte,debug lte1: network access technology: 3G
00:13:43 lte,info lte1: registered home
00:13:43 lte,async,raw lte1: $CREG: 1,"10b9","005e834c",2,"08d"
00:13:43 lte,async,event lte1: +CEN1: 1, 262, 01
00:13:43 lte,async,raw lte1: +CGREG: 1,"10b9","005e834c",2,1
00:13:46 lte,async,raw lte1: sent AT+CFUN?
00:13:46 lte,async,raw lte1: rcvd +CFUN: 1
00:13:46 lte,async,raw lte1: sent AT+COPS?
00:13:46 lte,async,raw lte1: rcvd +COPS: 0,0,"Telekom.de",2
00:13:48 lte,async,raw lte1: +CGREG: 1,"10b9","005e834c",6,1
00:13:48 lte,debug lte1: network access technology: 3G HSDPS & HSUPA
00:13:48 lte,async,raw lte1: +CREG: 1,"10b9","005e834c",6
00:13:48 lte,async,raw lte1: $CREG: 1,"10b9","005e834c",6,"08d"
00:13:48 lte,async lte1: sent AT+ZGACT=1,5
00:13:48 lte,async lte1: rcvd OK
00:13:49 lte,async,raw lte1: sent AT+CFUN?
00:13:49 lte,async,raw lte1: rcvd +CFUN: 1
00:13:49 lte,async,raw lte1: sent AT+COPS?
00:13:49 lte,async,raw lte1: rcvd +COPS: 0,0,"Telekom.de",6
00:13:50 lte,async,event lte1: +CNEC_GSM: 30,5
00:13:50 lte,async,event lte1: +CGEV: ME PDN DEACT 5
00:13:50 lte,async,event lte1: +ZCONSTAT: 0,5
00:13:54 lte,async,event lte1: +CNEC_GSM: 30,
00:13:55 lte,async lte1: sent AT+ZGACT=1,5
00:13:55 lte,async lte1: rcvd OK
00:14:05 lte,async,event lte1: +CNEC_GSM: 30,
00:14:16 lte,async,event lte1: +CNEC_GSM: 30,
00:14:27 lte,async,event lte1: +CNEC_GSM: 30,
00:14:38 lte,async,event lte1: +CNEC_GSM: 30,
00:14:38 lte,async,event lte1: +CNEMIU: 0
00:14:38 lte,async,event lte1: +CNEMS1: 1
00:14:38 lte,async,event lte1: +ZCONSTAT: 0,5
Maybe someone here could have a look and push me in the right direction? I would be eternally grateful!
Thanks and best regards,
Constantin
bump
Anyone has an idea?
I’m also on the same boat. I have an SXT LTE6, passthrough with IPv4 works great, but IPv6 passthrough doesn’t work. The client interface has a DHCPv6 client enabled, but it doesn’t receive the IPv6 address. If I disable passthrough, IPv6 address gets assigned to the Mikrotik device.
Is this not supported?
