Hi all
I am preparing to move on to ipv6, so I need to upgrade to mikrotik v5. Currently I have various licences, most are upgrade to “v3x”
Thank you
those which are ‘upgradable to v3.x’ can be upgraded for free if you use Netinstall.
Can I move on direclty from 3x to 5x without loosing config ? Or I have to go through v4 ?
yes, you can go to v5 directly with netinstall just in case, make an export file before you upgrade. “/export file=name” will give you a human readable backup file with the RSC extension, so you can recover in case of unexpected problems
