From what I have seen on the site, it states that the limitation is it only runs on tcp.
What it does not say, is that it requires a certain configuration, which is probably not compatible with most existing configurations outside of the routeros world, ie, it uses username + password for auth, instead of the more common certificates.
So, actually it has some pretty severe limitations. I’m hoping I’m missing something here, or is that it?
DNS Resolution.
Everything requires an ip address. For example, I want to be able to manually set an NTP server for an interface, (or an OpenVPN server) but I need to use an IP address instead of a domain name like time.wasted.org
Are these limitations here to stay?
I’m sorry to sound so critical on my first visit to the forums, I’m hoping I’m wrong, but I have this sinking feeling…
You are correct configuration accepts only IP address and as far as I know will stay that way. However script can be used to resolve DNS name and update configuration if IP is changed. We have even examples: http://wiki.mikrotik.com/wiki/Manual:Scripting-examples
