Limiting reported services
Hello to all.
I have, for example, a monitored printer for which the services ping, mikrotik, http, printer, tcp echo, and windows are enabled. If I delete any particular service in the device settings, because I simply don’t want to monitor it, on the next poll the deleted service is added back. Is there a way to permanently remove/disable services I don’t want to monitor?
Thanks.
To prevent this behaviour you should disable automatic network map
rediscovery, or disable particular services from being discovered. (open
network map → Settings → double click auto scan → select Services tab →
uncheck services that you don’t want to be reappearing)
