Limiting TCP, where is my mistake ?
Hello forum,
I try to limit the amount of TCP connections per hotspot user to 100.
This forum and MT wiki say, this rule does this :
chain=forward action=drop protocol=tcp connection-limit=100,32
What it should do :
In chain “forward” drop all tcp-packets for one client (32) who already has 100 tcp-connections.
Right now there is one user with 265 “established” TCP connections and some other (syn, wait, etc), and of course thousands of UDP “connections”
The statistics of this rule show nothing.
What do I do wrong ?
Can I limit the UDP streams/ports too ?
ROS is 4.11 on RB1000
You have to allow 100 connections and drop the rest. So you need two rules.
I think the default is, that everything that is not dropped, is allowed.
There are >200 connections without having a rule to allow them.
Maybe you can post the correct rules ?
I have the following rules now :
10   chain=forward action=accept protocol=tcp connection-limit=100,32
11   chain=forward action=drop protocol=tcp connection-limit=100,32
12   chain=forward action=reject reject-with=icmp-network-unreachable
     p2p=all-p2p protocol=tcp connection-limit=5,32
What it should do :
  • accept the first 100 TCP-connections
  • drop the rest
  • limit p2p connectione to 5 per user
Right now, one user has 18 p2p (bittorrent)
120 TCP, 47 UDP
Problems are :
  • many people can not use skype
  • at time of high traffic, some basic protocols like DHCP etc can not connect, because there are no connections available.
  • external loadbalancer is limited to 40000 simultanious sessions (in theory, CPU limit is less)
  • a P2P user uses 2200 to 2500 open sessions, and there are too many of them
I tried to fix this by setting up priorities, but also this does not work. It is taken from a script to a TikTube video :
Mangle :
0   chain=prerouting action=accept protocol=tcp dst-port=110
     packet-mark=Download_services
 1   chain=prerouting action=accept protocol=tcp dst-port=995
 2   chain=prerouting action=mark-packet new-packet-mark=Download_services
     passthrough=yes protocol=tcp dst-port=143
 3   chain=prerouting action=mark-packet new-packet-mark=Download_services
     passthrough=yes protocol=tcp dst-port=993
 4   chain=prerouting action=mark-packet new-packet-mark=Download_services
     passthrough=yes protocol=tcp dst-port=25
 5   chain=prerouting action=mark-packet new-packet-mark=Download_services
     passthrough=yes protocol=tcp dst-port=80 connection-bytes=500000-0
 6   chain=prerouting action=mark-packet new-packet-mark=Download_services
     passthrough=yes protocol=tcp dst-port=20
 7   chain=prerouting action=mark-packet new-packet-mark=Download_services
     passthrough=yes protocol=tcp dst-port=21
 8   chain=prerouting action=mark-packet new-packet-mark=Download_services
     passthrough=yes protocol=tcp dst-port=22 packet-size=1400-1500
 9   chain=prerouting action=mark-packet new-packet-mark=P2P_services
     passthrough=yes p2p=all-p2p
10   chain=prerouting action=mark-packet new-packet-mark=Ensign_services
     passthrough=yes protocol=tcp dst-port=53
11   chain=prerouting action=mark-packet new-packet-mark=Ensign_services
     passthrough=yes protocol=udp dst-port=53
12   chain=prerouting action=mark-packet new-packet-mark=Ensign_services
     passthrough=yes protocol=icmp
13   chain=prerouting action=mark-packet new-packet-mark=Ensign_services
     passthrough=yes protocol=tcp dst-port=443
14   chain=prerouting action=mark-packet new-packet-mark=Ensign_services
     passthrough=yes protocol=tcp dst-port=23
15   chain=prerouting action=mark-packet new-packet-mark=Ensign_services
     passthrough=yes protocol=tcp dst-port=22 packet-size=0-1400
16   chain=prerouting action=mark-packet new-packet-mark=Ensign_services
     passthrough=yes protocol=tcp dst-port=80 connection-bytes=0-500000
17   chain=prerouting action=accept packet-mark=User_requests
Queues :
 0   name="Prio 1" parent=global-in packet-mark=Ensign_services limit-at=0 queue=default priority=1 max-limit=0
     burst-limit=0 burst-threshold=0 burst-time=0s
 1   name="Prio 3" parent=global-in packet-mark=User_requests limit-at=0 queue=default priority=3 max-limit=0 burst-limit=0
 2   name="Prio 7" parent=global-in packet-mark=Download_services limit-at=0 queue=default priority=7 max-limit=0
 3   name="Prio 8" parent=global-out packet-mark=P2P_services limit-at=1k queue=default priority=8 max-limit=2k
Any hints ?
