limits on api
when i change , and i typed more ids
.id=1,2,3,4 …
how many ids can type and script run is successful ? 100 ,500, 1000 ?
as far as I know there are no explicitly specified limits.
so i can not met any obstacle ?
as mrz wrote - that should not be a problem.
also, consider that there is limit on how long the command can be, but that limit also is quite large.
