Link Information from both Routers on a ptp-link
I would like to see tx/rx errors from both sides of a ptp-link
on the link. So I need snmp-variables from both routers.
Can this be done?
Stefan
If that info is available through SNMP, you can look for it by doing a ‘SNMP Walk’.
The info is available. My problem is to place infos from 2 routers
on one link.
Ah, that’s a problem :slight_smile:
Wat you could do is split the link up into two parts with a (empty) ‘cloud’ device in the middle. Essentially you than have two links, but hey. Not pretty, but perhaps workable.
