I have had two cases of my customers who had Linksys wireless routers connected to my wireless service and it would appear that they generate DDOS like traffic on port 53 to our DNS service. I found I actually had to disconnect them from wireless to supress the issue. Even dropping response caused too much upstream traffic to cause a slowdown on the WLAN. We found it was the routers as they did it even when no PC’s were linked on their local side!
It does cause a nightmare when you have a lot of customers on the network. We have about 1500 customers on our network right now and about 90 percent of them have Linksys routers. It appears that they cause they DDOS attacks when they hold the reset button on their router with our connection still plugged in. We just stopped it from being an issue by putting every customer on their own VLAN. Now, the only connection they can mess with is their own .
The VLANs are split up between multiple Mikrotiks, about 300 each round numbers, however, I have successfully tested and run over 2000 VLANs in one Mikrotik router now that 2.9.18 is out. It did not work before 2.9.18.
What do you mean by a loop? How would that be possible under DNS settings to have a loop. I mean the DNS forwarder in the Linksys would talk to the DNS server it’s set to but what is the loop? I could only see that if local addresses were mirrored both sides of the NAT but then it just would not work?
A loop would be if someone plugged a hub or switch into … itself. I’ve seen these two, but they are very easily sourced to a single location with traffic graphs.
Right now, gigafast routers are the source of packet storms on our network. We are replacing them as they cause problems.
Also I have worked with the users and we are sure it’s not configuration issues. These users are quite knowlegeable. Also the linksys routers do it when idle. When being used by the end user the problem stops. One was bad when the user had gone to bed and just left his router switched on!
Crazy huh. I have had to add into TOS that users can be disconnected if using Linksys routers. Ha Ha… Good one linksys.
