I’m just starting my journey with networking and also Mikrotik
For my homelab I wanted to create a simple load balancing for a single local IP to some IP range, e.g.:
for 192.168.10.1 one of the addresses corresponds: 192.168.100.10-192.168.100.20
I know next to nothing about load-balancing trickery, but that seems very wrong to me. Stopping the packet after marking it drops it on the floor. Surely you want it to continue through the packet filter to have a decision applied to it, based on the mark?
If the rule you want applied is that srcnat one, note that it is in the postrouting chain, so it never even gets a chance to act in this configuration.
A clear set of requirements will lead to an optimal design
a. identify all users/devices that will interact on the network ( internal, external including admin)
b. identify all traffic flows they require
draw a diagram of what you wish to accomplish, identifying devices, WAN, vlans etc.
post your config of what you have accomplished thus far.
Reason @anav asks is there MANY ways to do load balance, and types of WAN matter. You seem to want to use “packet marking”, but in most cases “connection marking” is better. So details matter here.
Mikrotik has a video on the “PCC method” of load balancing: https://www.youtube.com/watch?v=nlb7XAv57tw
The firewall marking using “prerouting” rules shown in video common to all approaches.
Thanks for your response!
My network is really simple
As you can see, I’m working with /16 mask (VLANs I’ll introduce in the future). All of these, VMs are in the Proxmox but there is no firewall, NATs, or other. The IP addresses are static leases in Mikrotik.
Now, I want to create a simple load balancer on e.g. 192.168.35.1/16 for these machines so LAN for LAN, WAN is no matter in this scheme
Diagram and included detail is helpful.
However this statement needs to be broken down AS requested - it makes zero sense as stated… Now, I want to create a simple load balancer on e.g. 192.168.35.1/16 for these machines so LAN for LAN, WAN is no matter in this scheme
Identify users/devices
Identify traffic flow they require.
Users/devices are so many - 1, just me
If it comes to the traffic - these servers are K8s nodes, there will be not-so-complicated web servers without any special traffic.
The mentioned IPs connect servers on a diagram to each other and are also accessible by the rest of the network.
Actually queues are responsible for limiting traffic, anyway I think that you are mixing two different things together, you want something like HAProxy. Don’t you?
HAProxy is great, I’d also suggest that either caddyserver or Traefik in a container might be better approach here since those are bit simplier than HAProxy. If you search for forum for either, you’ll see how to do it on RouterOS. You also run any of these reverse proxy servers on Proxmox (Google or YouTube may help for here).
On the Mikrotik side, it’s just be a dst-nat rule to allow access to any proxy server. And the proxy server then load balances the actually HTTP (the session/application layer, Layer ~5-7)… vs router approaches like packets (Layer 2/3) or connections (Layer 3/4). The proxy server is also handy since both caddyserver and Traefik can automatically deal with ACME SSL certs. So the outside never have to see or know your 3 other VM – only the proxy server would need direct access & all other access to them goes via the reverse proxy.
If it’s not HTTP, the HAProxy may be better load balancer than caddyserver or Traefik.
I think you have a mental block any time “/container” get mentioned. . We kinda don’t know what protocol’s those VM servers are using – that the key detail to know here.
But, generally speaking, Proxmox support containers/“Docker”… so reverse proxy running there be more typical setup… e.g. if you have the 3 of similar VMs “doing some work” on proxmox based on incoming WAN traffic to the “cluster”.
Assuming need is from 1 x WAN to the 3 x VMs & you wanted to do this in RouterOS. Firewall could use PCC or ECMP* – just the src/dst address flopped from typical LAN->multiWAN. Since load balancing is from “single-WAN to multi-LAN” (well IPs)… All the same firewall mangle stuff for PCC apply, just with the src and dst address swapped. And I’d see queues as an “add-on” to PCC, rather than a substitute for PCC (or ECMP*). But if you’re already doing a mangle for PCC… you can add a packet market for use in queues to control latency for sure.
I’m more saying keeping it as “dst-nat” rule from WAN to some new proxy server on proxmox may be simplier approach… than a bunch of firewall mangling needed to do Mikrotik & these proxy have some UI to manage the load sharing without mucking with PCC (or queues). And, depending on protocol, some reverse proxy does more checks on liveness and have more options how to split the incoming load, than anything you could do on a Mikrotik.
#ProtocolsMatter
* For ECMP, you’d add new a route table with dst-address=0.0.0.0/0 listed three times, same scope/disance, just each with different gateway= with the VM’s IPs. Then, use some mangle action=mark-routing, based on protocol/port arriving on WAN, to send to need traffic the new route table. ECMP will divide the load based, only src-address (dst-address always be WAN IP, so not useful for ECMP hashing) – so if the traffic that’s getting split up is all coming from one far-end client… ECMP be a poor choice. e.g. PCC offers a “both-addresses-and-ports” choice, while ECMP does not just src/dest address.
