Currently i’m having trouble with load balancing with 3 ISP
ISP1: Dynamic IP
ISP2: Static IP
ISP3: Static IP
The problem is i can’t configure that 3 ISP line to load balance because ISP1 Have a dynamic ip which frequently change could anyone kind enough to help me with this ?
How exactly dynamic? If it’s from dhcp, it has support for lease script. If it’s PPPoE, it has something similar somewhere in PPP profile. And if the script looks too complex, another way is to create static config and only update some rule(s) (example).
Ok, small correction, it’s actually very easy with PPPoE, because it can simply use interface as gateway and doesn’t need any scripts (sorry, slipped my mind).
But what you do with DHCP? You need a routing table with gateway from DHCP, don’t you?
It depends. If ISP would have completely dynamic config where both address and default gateway can be different every time, any static config on your router wouldn’t work.
Routers don’t change IPs by themselves, but their admins can do that. There are two basic scenarios:
a) If there’s some additional router/modem between you and ISP and it actually works as router and RB get address from its DHCP server, then for you it’s like static config, nothing will change there.
b) If RB is connected directly to ISP and it gets address from their DHCP, you have no control over that. If ISP decides to use completely different network, any static config on RB will break. They probably won’t change it, because why would they, but it’s not impossible.
If you are using DHCP, you could call a simple “cleanup” script with each client lease change. Add similar script either to DHCP client section, or call it from there after adding it to the /system scripts section:
:global fwIP
:local dhcpIP
:local readIP [/ip address get value-name=address [/ip address find where actual-interface="ether1 - dhcp isp" and network!=192.168.0.0 and network!=192.168.100.0]];
:local dhcpGW [/ip dhcp-client get value-name=gateway number=0];
:set dhcpIP [:pick $readIP 0 [:find $readIP "/"]];
:if ($dhcpIP != $fwIP) do={
/ip firewall connection remove [find reply-dst-address~$fwIP]
:set fwIP $dhcpIP
/ip firewall address-list set [/ip firewall address-list find comment="WAN - dhcp"] address=$dhcpIP
/ip dns static set [/ip dns static find name="dhcp.gw"] address=$dhcpGW
/ip firewall nat set [/ip firewall nat find comment="src-nat"] to-addresses=$fwIP
:log info "dhcp WAN IP updated. NAT and routes fixed. Purged connections via dead IP."
If you have a local address for accessing your modem/router via DHCP gateway I explicitly added conditon not to look for local network. The loop that figures out that IP has changed alters various things that depend on the DHCP client and gateway IP.
You can adjust this to your liking and adjust it for PPPoE or similar client setups. I presume you would want to automatically alter mangle rules and policy routing, and this approach makes it possible.
