Load balancing between many mikrotik routerboards
i have three mikrotiks serving three client groups. each mikrotik runs a usermanager and pppoe service on the eth2 port
i want to join them all up and load balance between them all.
i am looking at this load balancing: http://wiki.mikrotik.com/wiki/NTH_load_balancing_with_masquerade_(another_approach) but the problem i have is that each mikrotik has its own group. to make this load balancing work i think i have to use only 1 usermanager, am i correct? But i should be able to run many pppoe services, or do i have to have only 1 pppoe service? pls correct me if i am wrong.
so, how should i go about setting it up from here? i just want to use all the available bandwidth from all the ISPs and load balance ALL the clients between them all.
here is a drawing of my current setup
