Load balancing - slow loading of websites and more
Hi, I bought a Mikrotik RouterBOARD RB962UiGS-5HacT2HnT hAP and this is my first experience with RouterOS. My main goal is to have Load balancing with ISP via DSL WAN1 (connected to Mikrotik from ISP router) and ISP Starlink WAN2 (connected to Mikrotik directly from the Starlink brick, so I am not using Starlink router).
On the first I tried a quick setup. When I connected to one ISP at the time, everything worked great.
I use this tutorial for setup of Load balancing https://youtu.be/GeuuNE3EPBA - should be same setup as well recommended MUM https://mum.mikrotik.com/presentations/LB19/presentation_6360_1548749570.pdf
WAN1 has distance 1 and WAN2 distance 2. I set it up like this, because Starlink WAN2 has a faster download than DSL WAN1.
I get in the Route List Starlink WAN2 as unreachable. I tried a few things to change but nothing helped. I decided to change Check gateway from ping to arp and that was it! Starlink WAN2 is from now on reachable.
If I try to disconnect Starlink WAN2 failover works pretty well. For example, youtube play video without interruption. When I connected WAN2 back, youtube stopped playing video and some apps like Signal showed “disconnected”. In RouterOS everything looks fine, like the handover worked.
Another issue is that loading of websites is really slow. It can take like a minute before it loads the UI of youtube. Another example, if I want to check speed on speedtest, it takes ±1 minute to “finding optimal server” and sometimes it will never find the optimal server or the speed check fails.
Sometimes websites does not loads at all and showing: This site can’t be reached - ERR_CONNECTION_CLOSED
Once again, if I use one ISP at the time, everything works great.
Please, anyone have some suggestions on how I could resolve these issues?
I would be happy if I can benefit from both ISPs at the same time. Like when I am downloading some game from steam, it would combine speeds. But that only works with link aggregation, right?
# nov/27/2021 18:27:03 by RouterOS 6.49.1
# software id = I2IK-I1QG
# model = RB962UiGS-5HacT2HnT
# serial number = E7D00F3639D9
add admin-mac=DC:2C:6E:3D:37:41 auto-mac=no comment=defconf name=bridge1
set [ find default-name=ether3 ] comment="ether3 - WAN1 - Tmobile" name=WAN1
set [ find default-name=ether1 ] comment="ether1 - WAN2 - Starlink" name=WAN2
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country="czech republic" disabled=no distance=indoors \
    frequency=auto installation=indoor mode=ap-bridge ssid=Metaverse \
    wireless-protocol=802.11 wps-mode=disabled
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
    dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=Sveta \
    supplicant-identity="" unicast-ciphers=tkip,aes-ccm
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country="czech republic" disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge name="wlan1 Sveta" security-profile=\
    Sveta ssid=Na_konci_sveta wireless-protocol=802.11 wps-mode=disabled
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge1 name=defconf
add bridge=bridge1 comment=defconf interface=ether4
add bridge=bridge1 comment=defconf interface=ether5
add bridge=bridge1 comment=defconf interface=sfp1
add bridge=bridge1 interface="wlan1 Sveta"
add bridge=bridge1 interface=wlan2
/interface detect-internet
set detect-interface-list=all
add comment=defconf interface=bridge1 list=LAN
add comment=defconf interface=WAN2 list=WAN
add interface=WAN1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=bridge1 network=\
    192.168.88.0
/ip dhcp-client
add add-default-route=no disabled=no interface=WAN1
add add-default-route=no disabled=no interface=WAN2
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip firewall mangle
add action=accept chain=prerouting dst-address=10.0.0.0/24 in-interface=\
    bridge1
add action=accept chain=prerouting dst-address=100.64.0.0/10 in-interface=\
    bridge1
add action=mark-connection chain=prerouting connection-mark=no-mark \
    in-interface=WAN1 new-connection-mark=WAN1_conn passthrough=yes
    in-interface=WAN2 new-connection-mark=WAN2_conn passthrough=yes
    dst-address-type=!local in-interface=bridge1 new-connection-mark=\
    WAN1_conn passthrough=yes per-connection-classifier=both-addresses:2/0
    WAN2_conn passthrough=yes per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting connection-mark=WAN1_conn \
    in-interface=bridge1 new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
    in-interface=bridge1 new-routing-mark=to_WAN2 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1_conn \
add action=mark-routing chain=output connection-mark=WAN2_conn \
add check-gateway=ping distance=1 gateway=10.0.0.138 routing-mark=to_WAN1
add check-gateway=arp distance=1 gateway=100.127.255.7 routing-mark=to_WAN2
add check-gateway=ping distance=2 gateway=10.0.0.138
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge1 type=internal
add interface=WAN2 type=external
/system clock
set time-zone-name=Europe/Prague
/tool mac-server
/tool mac-server mac-winbox
Your mangle rules seem a tad off… note one set of the rules needs to move (from spot 2 to spot 5)
(1 should be 1)
/ip firewall mangle
bridge1
bridge1
Remove in-interface=bridge (wrong)
For the dst-address that should be the network of the IP address of the WANIP.
(you will find it under IP address in winbox… probably a dynamic entry when connected).
For example
WANIP is 172.168.0.3 is the wanip under IP address, thus use 172.168.0.0/24 for dst-address in mangle rule.
(3 should be 2) (good)
(4 should be 3) (good)
(5 should be 4) (good)
(2 should be 5) GOOD but move these rules down to the end… (not sure if makes a difference but here is where I have seen them on other configs.
Thank you very much Anav!!! It helped! Works like charm. Next time I will start configurating with clean sheet. This time I was modifying config with quick setup configuration. So there were some Mangle rules from the beginning and it didn’t strike me, that order of rules will matter like that (face palm).
About WANIP, when I take WANIP from WAN2 Starlink under IP address, add it to dst-address in mangle rule, click on ok and it will automatically be changed to 100.64.0.0/10.
Few not important things.
It doesn’t load balance upload.
When I am downloading one big file, it will for example choose WAN1, after stopping and again activate download it will choose WAN2. If i want to use specific WAN only for few cases, like for downloading one big files or browsing a should add another mangle rules like this:
add dst-address=0.0.0.0/0 gateway=10.0.2.1 scope=255 target-scope=10 routing-mark="HTTP traffic" comment="" disabled=no
Please, is that correct?
Another weird thing happened, when I mess around with mangle rules and distance in Route rules, it didn’t work properly, so I return setting back and from now on, speedtest. net measuring speed only from single WAN. I tried downloading something from Steam and load balancing works as before. I was just bit scared that I broke something :smiley:
