I need to use mikrotik web proxy “just for logging get url addresses” with a load balance.
If i use ppc load balance proxy uses only one wan connection.
Is there any way that, i can use mikrotik proxy with some kind of load balancing on same device 493G or 1100AH.
yes pcc sorry, i can use ecmp of course if it works i am open to suggestions. Can’t find any thing about using internet proxy with load balance
I just need some kind of load balance which works with mikrotiks built in proxy opened
… and for my little experience i think ecmp is the simpler way to have load balancing.
Web proxy is on a complete different level than load balancing, you must look at the two thing separtely: each load balancing can go with web proxy, just you can’t expect to classify trafic based on src address.
Yes.. I know, i need web proxy because of two things.
1-Client wants to block all internet access allow users to connect through only allowed url’s ‘blocking content works with firewall but allowing does not work’.
2-He needs a web proxy output for logging web sites
I have already used my Mikrotik below setup for PCC Load Balancing with Web Proxy.
I hope it will be work for all.
I am working on MikriTik RouterOS 5.23 (X86)
My Mikrotik has 3 interface.
