Local connection to nated gameserver very slow / high ping
first of all im very new in Mikrotik and im very happy that i got internet working :smiley: (btw. my english is not perfect sry)
My Setup is a fritzbox as modem, behind it a mikrotik Router… Connection to internet is made by mikrotik router via pppoe
All my Clients are connected to the mikrotik router and all of them have working internet and dns (as far i can see)
one of my clients is a gameserver via docker on unraid… This stuff worked all perfectly with my old router (fritzbox)
My Problem is that i get very high pings if im connected to the gameservers. My Friends, that are connecting from outside my homenetwork does not have this problem so i guess it is something stupid in my config (this hairpin stuff is rly new to me have not needed this before). A result is that i need to wait sometimes around 5 minutes until the game check that i have made some inputs :smiley:
Also the Portforwarding is a bit different as i thought… Here is my config (this is a WIP and all tips are welcome)
# 2025-03-24 21:03:08 by RouterOS 7.18.2
# software id = KEEF-Y536
# model = C53UiG+5HPaxD2HPaxD
# serial number = #############
add name=bridge1
set [ find default-name=ether1 ] loop-protect=off
/interface wifi
set [ find default-name=wifi1 ] configuration.country=Germany .mode=ap .ssid=\
    Dingsbums .station-roaming=yes disabled=no security.authentication-types=\
    wpa2-psk,wpa3-psk .encryption=""
set [ find default-name=wifi2 ] configuration.country=Germany .mode=ap .ssid=\
    Dingsbums disabled=no security.authentication-types=wpa2-psk,wpa3-psk \
    .encryption=""
/interface pppoe-client
add add-default-route=yes allow=pap,chap,mschap2 disabled=no interface=ether1 \
    name=telekom use-peer-dns=yes user=\
add name=WAN
add name=LAN
/interface wifi security
add authentication-types=wpa-psk,wpa2-psk disabled=no encryption=\
    tkip,ccmp,gcmp,ccmp-256,gcmp-256 name=wpa_profiile
add name=dhcp_pool0 ranges=192.168.2.2-192.168.2.254
add address-pool=dhcp_pool0 interface=bridge1 lease-time=7h30m name=dhcp1
/ipv6 pool
add name=telekom.ipv6 prefix=::/56 prefix-length=64
add bridge=bridge1 disabled=yes interface=wifi1
add bridge=bridge1 interface=wifi2
add bridge=bridge1 interface=wifi1
# ipv6 *accept router advertisements* configuration has changed, please restart device to apply settings
/ip settings
set accept-redirects=yes
/ipv6 settings
set accept-router-advertisements=yes
add interface=ether1 list=WAN
add interface=telekom list=WAN
/interface ovpn-server server
add mac-address=FE:BA:63:7F:C2:23 name=ovpn-server1
add address=192.168.2.1/24 interface=bridge1 network=192.168.2.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=5m
/ip dhcp-client
add disabled=yes interface=ether1
/ip dhcp-server lease
add address=192.168.2.141 address-lists="192.168.2.153,192.168.2.139,192.168.2\
    .143,192.168.2.154,192.168.2.142,192.168.2.110" comment=Unraid \
    mac-address=B0:41:6F:0E:98:51 server=dhcp1
add address=192.168.2.124 comment=docker-master mac-address=38:F7:CD:C1:DB:2D \
    server=dhcp1
add address=192.168.2.42 comment=gitlabrunner mac-address=52:54:00:5B:1B:68 \
    server=dhcp1
add address=192.168.2.40 comment=Harbor mac-address=52:54:00:79:24:FB server=\
    dhcp1
add address=192.168.2.123 comment=nas mac-address=00:13:3B:2F:25:80 server=\
    dhcp1
add address=192.168.2.100 comment="Netgear Switch" mac-address=\
    B0:39:56:70:33:41 server=dhcp1
add address=192.168.2.51 comment=rpi8-gb mac-address=E4:5F:01:6E:FD:27 \
    server=dhcp1
add address=192.168.2.50 comment="\C2\A0rpi-400-4gb" mac-address=\
    E4:5F:01:27:28:B2 server=dhcp1
add address=192.168.2.43 comment=zaproxy mac-address=52:54:00:93:36:C1 \
    server=dhcp1
add address=192.168.2.35 client-id=1:fa:b5:a:57:29:80 mac-address=\
    FA:B5:0A:57:29:80 server=dhcp1
add address=192.168.2.33 client-id=1:24:58:7c:ab:fb:ec mac-address=\
    24:58:7C:AB:FB:EC server=dhcp1
add address=192.168.2.34 mac-address=AC:15:A2:DD:78:93 server=dhcp1
add address=192.168.2.0/24 gateway=192.168.2.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.2.43 comment=tower regexp=*.home.lan type=A
/ip firewall address-list
add address=*********** list=WAN-IP
add action=accept chain=forward connection-state=established,related
add action=drop chain=input connection-state=new dst-address-list=WAN-IP \
    dst-port=53 protocol=udp
add action=drop chain=input dst-address-list=WAN-IP dst-port=53 protocol=tcp
add action=accept chain=input connection-state=new
add action=drop chain=input connection-state=invalid
add action=accept chain=input in-interface-list=LAN
add action=accept chain=input comment=steam disabled=yes dst-address-list=\
    WAN-IP dst-port=3478 protocol=udp
add action=accept chain=input connection-state=related disabled=yes
add action=accept chain=input disabled=yes
add action=accept chain=output connection-nat-state=srcnat,dstnat \
    connection-state=established,related,new
add action=accept chain=forward dst-address-list=WAN-IP dst-port=25565-25620 \
    protocol=udp
add action=accept chain=input dst-address-list=WAN-IP dst-port=4379-4380 \
    protocol=udp
add action=accept chain=input dst-address-list=WAN-IP dst-port=25565-25620 \
    protocol=tcp
    protocol=udp
add action=accept chain=input dst-address-list=WAN-IP dst-port=27000-27050 \
    protocol=tcp
    protocol=udp
add action=drop chain=forward connection-nat-state=!dstnat connection-state=\
    established,related,new dst-address-list=WAN-IP log=yes log-prefix=\
    dropforward
add action=accept chain=forward connection-nat-state=dstnat \
    in-interface-list=WAN log-prefix="forward dstnat"
add action=fasttrack-connection chain=forward connection-state=\
    established,related hw-offload=yes
add action=accept chain=forward comment="Allow Port forwarding" \
    connection-state=established,related,new,untracked
add action=accept chain=forward comment="Internet Traffic" in-interface-list=\
    LAN out-interface-list=WAN
add action=accept chain=forward connection-nat-state=dstnat disabled=yes
add action=drop chain=input log-prefix="input block"
add action=masquerade chain=srcnat comment="Hairpin NAT" dst-address=\
    192.168.2.0/24 src-address=192.168.2.0/24
add action=dst-nat chain=dstnat disabled=yes dst-address-list=WAN-IP \
    dst-port=80 protocol=tcp to-addresses=192.168.2.43 to-ports=80
    dst-port=443 protocol=tcp to-addresses=192.168.2.43 to-ports=443
    dst-port=25565-25620 protocol=tcp to-addresses=192.168.2.141
add action=dst-nat chain=dstnat connection-limit=100,32 disabled=yes \
    dst-port=25565-25620 protocol=udp to-addresses=192.168.2.141
    dst-port=27000-27050 protocol=tcp to-addresses=192.168.2.141
    dst-port=27000-27050 protocol=udp to-addresses=192.168.2.141
    dst-port=3478 protocol=udp to-addresses=192.168.2.141
    dst-port=4379-4380 protocol=udp to-addresses=192.168.2.141
add action=dst-nat chain=dstnat dst-address-list=WAN-IP dst-port=25565-25620 \
add action=dst-nat chain=dstnat dst-address-list=WAN-IP dst-port=27000-27030 \
add action=dst-nat chain=dstnat comment="zaproxy https" dst-address-list=\
    WAN-IP dst-port=443 log-prefix=ssl protocol=tcp to-addresses=192.168.2.43
add action=masquerade chain=srcnat comment=Masquerade out-interface=telekom \
add action=dst-nat chain=dstnat comment="zaproxy http" dst-port=80 \
    in-interface-list=WAN protocol=tcp to-addresses=192.168.2.43
add action=dst-nat chain=dstnat dst-port=25000 in-interface-list=WAN \
    protocol=tcp to-addresses=192.168.2.141 to-ports=25000
/ip ipsec profile
/ip service
set telnet address=192.168.2.0/24
set ftp address=192.168.2.0/24
set www address=192.168.2.0/24
set ssh address=192.168.2.0/24
set api address=192.168.2.0/24
set winbox address=192.168.2.0/24
set api-ssl address=192.168.2.0/24
/ip traffic-flow
set enabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge1 type=internal
add interface=telekom type=external
/ipv6 address
# duplicate address detected
add from-pool=telekom.ipv6-2 interface=bridge1
/ipv6 dhcp-client
add add-default-route=yes interface=telekom pool-name=telekom.ipv6-2 request=\
    prefix
/ipv6 dhcp-server
add address-pool=telekom.ipv6-2 interface=bridge1 name=server1 prefix-pool=\
    telekom.ipv6-2
/ipv6 firewall filter
add action=accept chain=input protocol=icmpv6
add action=accept chain=forward dst-port=546 protocol=udp src-address=\
    fe80::/10
/ipv6 nd
set [ find default=yes ] interface=bridge1
/system clock
/system note
set show-at-login=no
/system ntp client
set mode=broadcast
/system ntp server
set broadcast=yes enabled=yes manycast=yes multicast=yes
/system ntp client servers
/tool mac-server
/tool mac-server mac-winbox
Any Idea how i can fix this local stuff issues?
in the time of waiting for approval here, i have done a full backup and after that i restored default configs, made my changes to fit my network, added my wifi and ipv6 but its still the same, very very high pings in game server just from local connection. Connections from outside working as expected.
Cant believe that a MK router is having this kind of trouble in performance vs a fritzbox…
But im sure its just a config issue…
Here my current config after reset… Firewall rules and co was in there too this time :smiley: so i let them in and just added my port nat
# 2025-03-25 01:06:48 by RouterOS 7.18.2
add admin-mac=F4:1E:57:2A:33:61 auto-mac=no comment=defconf name=bridge
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
    configuration.country=Germany .mode=ap .ssid=Dingsbums disabled=no \
    security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
    name=telekom user=***************
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.2.10-192.168.2.254
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add address=192.168.2.1/24 comment=defconf interface=bridge network=\
    192.168.2.0
/ip cloud
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=192.168.2.141 client-id=1:b0:41:6f:e:98:51 mac-address=\
    B0:41:6F:0E:98:51 server=defconf
add address=192.168.2.43 client-id=1:52:54:0:93:36:c1 mac-address=\
    52:54:00:93:36:C1 server=defconf
add address=192.168.2.42 client-id=1:52:54:0:5b:1b:68 mac-address=\
    52:54:00:5B:1B:68 server=defconf
add address=192.168.2.40 client-id=1:52:54:0:79:24:fb mac-address=\
    52:54:00:79:24:FB server=defconf
add address=192.168.2.50 client-id=1:e4:5f:1:27:28:b2 mac-address=\
    E4:5F:01:27:28:B2 server=defconf
add address=192.168.2.0/24 comment=defconf dns-server=192.168.2.1 gateway=\
    192.168.2.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.2.1 comment=defconf name=router.lan type=A
add address=*************** comment=WAN-IP list=WAN-IP
    established,related,untracked
    invalid
add action=accept chain=input in-interface=!telekom src-address=\
    192.168.2.0/24
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=dst-nat chain=dstnat dst-address-list=WAN-IP dst-port=80 protocol=\
add action=dst-nat chain=dstnat dst-address-list=WAN-IP dst-port=443 \
add action=dst-nat chain=dstnat connection-limit=100,32 dst-address-list=\
    WAN-IP dst-port=25565-25620 protocol=udp to-addresses=192.168.2.141
add action=dst-nat chain=dstnat dst-address-list=WAN-IP dst-port=27000-27050 \
add action=dst-nat chain=dstnat dst-address-list=WAN-IP dst-port=3478 \
add action=dst-nat chain=dstnat dst-address-list=WAN-IP dst-port=4379-4380 \
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
/ipv6 address
add address=::1 from-pool=telekom.ipv6 interface=bridge
/ipv6 dhcp-client
add add-default-route=yes interface=telekom pool-name=telekom.ipv6 request=\
    prefix
/ipv6 dhcp-server
add address-pool=telekom.ipv6 interface=bridge name=server1 prefix-pool=\
    telekom.ipv6
/ipv6 firewall address-list
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/ipv6 nd
set [ find default=yes ] hop-limit=64 interface=bridge
/system clock
/system note
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system routerboard wps-button
set enabled=yes on-event=wps-accept
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
add comment=defconf dont-require-permissions=no name=wps-accept owner=*sys \
    source="\r\
    \n   :foreach iface in=[/interface/wifi find where (configuration.mode=\"a\
    p\" && disabled=no)] do={\r\
    \n     /interface/wifi wps-push-button \$iface;}\r\
    \n "
/tool mac-server
Nobody has an idea or tip how i can fix or analyse this issue? No tips or suggestions at all with the rules? Im surpressed :smiley:
Or are here more informations needed? If so which information?
Well… your setup seems ok based on a cursory reading.
How high do your pings get? Compared to your friends?
Make sure that you are addressing your server via the router’s external address even from the inside.
You can always enable logging for your hairpin nat rule to check if all the address translations work out correctly.
(This does not really relate to your problem of high pings, but it’s generally a good idea to do things like running a private game server over some sort of VPN for security reasons.)
Actually, fritz box devices are terrible modems.
But why do you have the same NAT rule multiple times?
Hi lurker,
I got Pings between 800ms and 350000ms, disabling fasttrack made it a bit better i was much higher pings with fasttrack… my friends are in a normal range between 10 and 20ms, in peaks around 30ms
The connection to the server is made by steam networking so its always from outside, i connect to a steam server and from there it goes to my gameserver. it is not reachable from within my lan network because there is no connection to steam directly.
With my old fritzbox this works like a charm thats the point where i dont get it right now
hi itimo,
which rules are duplicates?
oh i see yeah there duplicates in but all with count 0… this was a test i tried without WAN-IP but that did not helped so i forgot to disable the 4 rules
Your export has this one multiple times:
if that’s not the case check your export again and post a new config
Also on your screenshot your NAT rules have 0B Transferred. You sure theyre working?
nvm i didnt read that far while playing a game ^^
EDIT: also that “hairpin nat” rule is never gonna work. As you never actually access the server with the 2.141 IP if you’re using your WAN-Address
You must use your wan IP as dst-address.
Check this:
http://forum.mikrotik.com/t/hairpin-nat-the-easy-way/146718/1
here is the current config
# 2025-03-25 23:17:20 by RouterOS 7.18.2
set [ find default-name=ether1 ] advertise=\
    1G-baseT-half,1G-baseT-full,2.5G-baseT rx-flow-control=auto \
    tx-flow-control=auto
set [ find default-name=ether5 ] advertise=1G-baseT-half,1G-baseT-full
/interface wifi
    max-mru=1500 max-mtu=1500 name=telekom user=\
/disk settings
/interface detect-internet
set detect-interface-list=WAN internet-interface-list=WAN lan-interface-list=\
    LAN wan-interface-list=WAN
    192.168.2.0
/ip cloud
/ip dhcp-client
    192.168.2.1
/ip dns static
add address=************ comment=WAN-IP list=WAN-IP
    invalid
    192.168.2.0/24
    connection-state=established,related disabled=yes hw-offload=yes
add action=masquerade chain=srcnat comment="Hairpin NAT" disabled=yes \
    dst-address=192.168.2.0/24 log=yes log-prefix=hairpin src-address=\
    192.168.2.0/24
    dst-port=27000-27030 protocol=tcp to-addresses=192.168.2.141
    dst-port=27000-27030 protocol=udp to-addresses=192.168.2.141
/ip service
set www disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
/ipv6 address
/ipv6 dhcp-client
    prefix
/ipv6 dhcp-server
    telekom.ipv6
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/ipv6 nd
/system clock
/system note
/system scheduler
add interval=1d name=backup policy=\
    start-date=2025-03-25 start-time=01:13:44
/system script
    source="\r\
    \n   } else={\r\
    \n   }\r\
    \n "
    source="\r\
    \n "
/tool mac-server
/tool netwatch
add disabled=no down-script="" host=192.168.2.141 http-codes="" test-script=\
    "" type=simple up-script=""
/tool sniffer
set filter-ip-address=192.168.2.141/32
yes they work because this rules are hittet onetime only and the other entry works fine
The hairpin is needed if you want access to a webserver from within the network, its needed with mikrotik. without the rule i have no access to my internal websites. Not sure if this is a best practice but thats the only solution i found to get it working
The Hairpin rule is still wrong.
Hairpin NAT is for natting the ROUTER IP to a service. Not a whole subnet to each other.
So if ANYTHING from subnet 2.0/24 to subnet 2.0/24
So if client 2.20 tries to access 2.30:25565 it will be natted to 2.141
Not even sure if this works as both are on the same broadcast domain on a bridge
Check the forum post i linked
EDIT:
Do you try to access the server with your WAN IP?
If not: then why the hairpin rule?
Just access the server with its own IP-Address?
If yes: then your hairpin rule is even more wrong :smiley:
ok got the point with using same port on different machines in lan so i used the solution from your post because it should work better internaly, my internal webservices are still working yeah :smiley:
here is my current config
# 2025-03-25 23:46:23 by RouterOS 7.18.2
# serial number = ##############
/interface wifi
/disk settings
    192.168.2.0
/ip cloud
/ip dhcp-client
    192.168.2.1
/ip dns static
add address=################ comment=WAN-IP list=WAN-IP
add address=192.168.2.0/24 comment="Lan Subnet" list=LAN-subnet
    invalid
    192.168.2.0/24
/ip firewall mangle
add action=mark-connection chain=prerouting comment=\
    "Mark connections for hairpin NAT" dst-address-list=WAN-IP \
    new-connection-mark="Hairpin NAT" src-address-list=LAN-subnet
add action=masquerade chain=srcnat comment="Hairpin NAT" connection-mark=\
    "Hairpin NAT"
    192.168.2.0/24
/ip service
/ip upnp
set enabled=yes
/ip upnp interfaces
/ipv6 address
/ipv6 dhcp-client
    prefix
/ipv6 dhcp-server
    telekom.ipv6
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/ipv6 nd
/system clock
/system note
/system scheduler
/system script
    source="\r\
    \n   } else={\r\
    \n   }\r\
    \n "
    source="\r\
    \n "
/tool mac-server
/tool netwatch
/tool sniffer
thats the point, the connection is made via steam network and they use the WAN-IP, so my traffic to this server is goint from my machine .2.254 via WAN-IP to Steam Network and from there back to WAN-IP:gameport and is natted there to my internal .2.141:gameport
If yes: then your hairpin rule is even more wrong > :smiley:
As i said, the hairpin is not needed for it its just for accessing my internal services from within the lan himself where dns responding my WAN-IP
EDIT:
hmm after changing hairpin it looks that my port forwardings are not working anymore from outside the lan
hmm kinda forgot the part about Steam Networking.
To explain the high ping:
Its because of a configuration issue.
Steam Networking first tries to connect to the Server-IP:Port.
If that doesn’t work, it will use a Proxy. Which obviously will route traffic to one of Steams servers and then back to you.
Since your hairpin nat didn’t make any sense, it used the proxy just for you.
Hairpin rule looks good now.
How are you testing this?
It might also be good to clean up that mess of NAT rules.
Also, why do you have a connection-limit enabled on the 25565-25620/udp rule?
Thats the reason why im asking the pro’s here :smiley: i dont see a config issue but im not a mikrotik pro
But yes make sense because now i have this log entrys and this massage i get because the connection via configured ports are not possible
Game Port: 25587
Steam Port: 25590
Steam Query Port: 25588
Query Port: 25589
Steam Networking initialized.
WARNING: Query port change detected.
       - The dedicated server window will not find this server.
       - Players will be able to join via the server browser.
       - Players won't find this server in the 'Join via IP' and 'Join LAN' windows.
i see the gameserver ingame in serverbrowser but the ping is now around 500-800 in my 30 sec test..
i used https://portchecker.co/ to check if the ports are open and they don’t. I tried also some other portchecker but there responding all closed and they should be open. The rule is not hitted since counter reset so something is rly strange and i dont see where.
have no idea, saw the same and thought that is my issue. So i disabled it, tryed ingame but nothing changed… i guess it was a missklick in winbox what enabled this limit
i cleaned it up now, here is again the new config
# 2025-03-26 00:34:27 by RouterOS 7.18.2
# serial number = #################
/interface wifi
/disk settings
    192.168.2.0
/ip cloud
/ip dhcp-client
    192.168.2.1
/ip dns static
add address=############### comment=WAN-IP list=WAN-IP
    invalid
    192.168.2.0/24
/ip firewall mangle
    "Hairpin NAT"
    protocol=udp to-addresses=192.168.2.141 to-ports=25565-25620
/ip service
/ip upnp
set enabled=yes
/ip upnp interfaces
/ipv6 address
/ipv6 dhcp-client
    prefix
/ipv6 dhcp-server
    telekom.ipv6
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/ipv6 nd
/system clock
/system note
/system scheduler
/system script
    source="\r\
    \n   } else={\r\
    \n   }\r\
    \n "
    source="\r\
    \n "
/tool mac-server
/tool netwatch
/tool sniffer
Thank you so much for your time! I realy appreciate it
Are you sure you have a static ipv4?
German Telekom usually only offers those on their business contracts.
Otherwise check that your WAN-IP Address List is the same as your actual Public IPv4. (for example: https://wieistmeineip.de - German Service)
Since you have rebooted the router your PPPoE conection has restarted which might mean you get a new IPv4 with a new IPv6 Prefix.
If you have a dynamic IP you probably need a script to update the Address List but for testing you can manually update the Address List entry.
No its a dynamic ip which is updated on every reconnect. It resolves the public dns name from IP-> Cloud and write the ip into a list
The List reflects my current IP
Port 443 shows open and if i enter the ip into browser i land on my default host so im sure that WAN-IP is the right one
Hmm IPv6…just a stupid question, are all the port forwards needed for ipv6 to? because the ip-> Cloud shows the ipv6 from router and not from the server himself. Not sure if steam uses ipv4 or ipv6 to connect to server
According to some people its ipv4 only. As some games dont even support ipv6
https://steamcommunity.com/discussions/forum/1/4625855867810531813/
For me it also usually just runs on ipv4.
If your game server is source/goldsrc engine based, it should show the ip it uses in the startup log.
Keep in mind you will have to restart the server when your ipv4 changes.
This is because the game server advertises itself to the Server list.
Well that seems like the hairpin nat is working. Is it the same on for example your phones data?
a great so ipv6 doesnt matter…
The Gameserver is in a docker and is bound to 0.0.0.0 / 192.168.2.141 on the defined ports.
i know that i have to restart every time but it is not working before a reconnect and not after a pppoe reconnect.
The server himself is working fine from outside the lan perfectly (i guess from outside they using the same steam proxy as me and there ping is normal). Its also working from inside lan just with a very high ping for me only.
And that all port checker are showing port as closed is bit confusing because it should be open i guess… i think the steam api is trying to connect to the provided WAN IP and thats not working because port is closed but i see traffic on the rules (just made a new range just for this one avorion gameserver)
But its not much traffic… 19 packets since a half hour where i changed it and there is no traffic if i connect in the hosted server so its using a different port and not that ports that are configured what is very crazy
EDIT:
If its in wlan yes
So on LTE/4G/5G it doesn’t work?
Probably not. I have only bad experiences with the Steam Proxys.
You should see the client IP in the routers connection list.
What should i test from 5G? Connection to my webserver? Thats working but thats working all the time and thats also working without the hairpin and before we changed the hairpin config
The Porttester also respond closed if i made the test from phone but that is expected because they using the server ip from port tester not from my wan or phone
Im sure i would but without knowing which port the server is using it could be every of this connections :smiley:
so i guess if i get the port forwarding stuff working it should be fine again i guess… if i remember right the forwarded ports within fritzbox shows as opened in the porttesters.
I feel like this is going in circles right now
Yes. Then you have a connection from outside.
I think we means the same or is missunderstood something, sry…
in the meantime i enabled logging on the nat rules and there is traffik on the configured steam query port…
But still
Server connected to Steam successfully
Server is VAC Secure!
Game Server Steam ID: 90263359915329559
Game Port: 25710
Steam Port: 25707
Steam Query Port: 25708
Query Port: 25709
If you're running multiple servers, you may want to look at binding the server to an ip with the --ip option.
But i can connect just with a high ping so yes i guess there is a loop or something like this from my local client to server connection… is it possible to disable this damnit hairpin stuff and just overwrite for me internaly the dns answer that are provided to my lan clients? Just for testing if its working without this hairpin stuff
Edit: i forgot the picture :smiley:
The Traffic is just on this one port not on other ports like gameport and co… very confusing
