Log File
My simple question is …..Can the Log File be exported so I can document it?
Yes
/log print file=log.txt
A remote syslog might b a better option depending on intended use.
https://wiki.mikrotik.com/wiki/Manual:System/Log
Thanks, I knew the command was a simple one. I am going the setup a syslog server so I can more readily track the messages.
Look at my project for using Syslog to monitor Mikrotik Router using Splunk.
http://forum.mikrotik.com/t/tool-using-splunk-to-analyse-mikrotik-logs-3-3-graphing-everything/121810/1
That is a very impressive and detailed post. This is why I am getting better with Mikrotik, all the quality help available. Thank you.
