Hello. Found an interesting point. In the log with the topic systems, info there are empty lines. I am experiencing the issue on three devices 951Ui-2HnD, RBD52G-5HacD2HnD, RB750Gr3.
ROS v7.2.3
What could it be?
22:17:59 system,info router rebooted
22:18:04 interface,info flatgate link up
22:18:05 interface,info vlan1 link up
22:18:05 interface,info vlan2 link up
22:18:05 bridge,info "bridgeCL1" mac address changed to E4:8D:8C:66:C3:A6
22:18:06 ovpn,info x-hosting: initializing...
22:18:06 ovpn,info x-hosting: connecting...
22:18:06 ovpn,info x-hosting: terminating... - could not connect
22:18:06 ovpn,info x-hosting: disconnected
22:18:06 system,info
22:18:06 bridge,info "bridgeLC" mac address changed to E4:8D:8C:66:C3:A5
22:18:06 interface,info lte1 link up
22:18:06 bridge,info hardware offloading activated on bridge "bridgeLAN" ports: ether4,ether3,ether2,ether5
22:18:07 ovpn,info x-hosting: initializing...
22:18:07 ovpn,info x-hosting: connecting...
22:18:07 ovpn,info x-hosting: terminating... - could not connect
22:18:07 ovpn,info x-hosting: disconnected
22:18:07 interface,info lte1 link down
22:18:08 interface,info ether1 link up (speed 100M, full duplex)
22:18:08 interface,info ether2 link up (speed 100M, full duplex)
22:18:08 interface,info ether3 link up (speed 100M, full duplex)
22:18:08 interface,info ether4 link up (speed 10M, full duplex)
22:18:08 ovpn,info x-hosting: initializing...
22:18:08 ovpn,info x-hosting: connecting...
22:18:08 ovpn,info x-hosting: terminating... - could not connect
22:18:08 ovpn,info x-hosting: disconnected
22:18:09 interface,info lte1 link up
22:18:11 dhcp,info dhcp-client on lte1 got IP address 192.168.5.100
22:18:11 ovpn,info x-hosting: initializing...
22:18:11 ovpn,info x-hosting: connecting...
22:18:12 ovpn,info x-hosting: terminating... - could not connect
22:18:12 ovpn,info x-hosting: disconnected
22:18:14 dhcp,info dhcp-client on bridgeLC got IP address 192.168.2.200
22:18:14 system,info,account user trx logged in from 192.168.9.11 via winbox
22:18:15 system,info
22:18:18 interface,info cl1 link up
22:18:18 ovpn,info x-hosting: initializing...
22:18:18 ovpn,info x-hosting: connecting...
22:18:19 interface,info flat-lan link up
22:18:20 ovpn,info x-hosting: using encoding - AES-256-CBC/SHA1
22:18:20 ovpn,info x-hosting: connected
22:18:20 dhcp,info dhcp-client on bridgeCL1 got IP address 192.168.40.110
22:18:42 system,critical,info ntp change time Jun/01/2022 22:18:42 => Jun/01/2022 22:19:03
