Completely useless in the context of this topic.
SINGLE MESSAGE FOR EACH LOGS VERSION:
:global anydate2isodate do={
:local dtime [:tostr $1]
/system clock
:local cyear [get date] ; :if ($cyear ~ "....-..-..") do={:set cyear [:pick $cyear 0 4]} else={:set cyear [:pick $cyear 7 11]}
:if (([:len $dtime] = 10) or ([:len $dtime] = 11)) do={:set dtime "$dtime 00:00:00"}
:if ([:len $dtime] = 15) do={:set dtime "$[:pick $dtime 0 6]/$cyear $[:pick $dtime 7 15]"}
:if ([:len $dtime] = 14) do={:set dtime "$cyear-$[:pick $dtime 0 5] $[:pick $dtime 6 14]"}
:if ([:len $dtime] = 8) do={:set dtime "$[get date] $dtime"}
:if ([:tostr $1] = "") do={:set dtime ("$[get date] $[get time]")}
:local vdoff [:toarray "0,4,5,7,8,10,11,19"]
:local MM [:pick $dtime ($vdoff->2) ($vdoff->3)]
:if ($dtime ~ ".../../....") do={
:set vdoff [:toarray "7,11,1,3,4,6,12,20"]
:set MM ([:find "xxanebarprayunulugepctovecANEBARPRAYUNULUGEPCTOVEC" [:pick $dtime ($vdoff->2) ($vdoff->3)] -1] / 2)
:if ($MM>12) do={:set MM ($MM - 12)} ; :if ($MM<10) do={:set MM "0$MM"}
:return "$[:pick $dtime ($vdoff->0) ($vdoff->1)]-$MM-$[:pick $dtime ($vdoff->4) ($vdoff->5)] $[:pick $dtime ($vdoff->6) ($vdoff->7)]"
:global UTF8toURLencode do={
:local ascii "\00\01\02\03\04\05\06\07\08\09\0A\0B\0C\0D\0E\0F\
\10\11\12\13\14\15\16\17\18\19\1A\1B\1C\1D\1E\1F\
\20\21\22\23\24\25\26\27\28\29\2A\2B\2C\2D\2E\2F\
\30\31\32\33\34\35\36\37\38\39\3A\3B\3C\3D\3E\3F\
\40\41\42\43\44\45\46\47\48\49\4A\4B\4C\4D\4E\4F\
\50\51\52\53\54\55\56\57\58\59\5A\5B\5C\5D\5E\5F\
\60\61\62\63\64\65\66\67\68\69\6A\6B\6C\6D\6E\6F\
\70\71\72\73\74\75\76\77\78\79\7A\7B\7C\7D\7E\7F\
\80\81\82\83\84\85\86\87\88\89\8A\8B\8C\8D\8E\8F\
\90\91\92\93\94\95\96\97\98\99\9A\9B\9C\9D\9E\9F\
\A0\A1\A2\A3\A4\A5\A6\A7\A8\A9\AA\AB\AC\AD\AE\AF\
\B0\B1\B2\B3\B4\B5\B6\B7\B8\B9\BA\BB\BC\BD\BE\BF\
\C0\C1\C2\C3\C4\C5\C6\C7\C8\C9\CA\CB\CC\CD\CE\CF\
\D0\D1\D2\D3\D4\D5\D6\D7\D8\D9\DA\DB\DC\DD\DE\DF\
\E0\E1\E2\E3\E4\E5\E6\E7\E8\E9\EA\EB\EC\ED\EE\EF\
\F0\F1\F2\F3\F4\F5\F6\F7\F8\F9\FA\FB\FC\FD\FE\FF"
:local UTF8toURLe {"00";"01";"02";"03";"04";"05";"06";"07";"08";"09";"0A";"0B";"0C";"0D";"0E";"0F";
"10";"11";"12";"13";"14";"15";"16";"17";"18";"19";"1A";"1B";"1C";"1D";"1E";"1F";
"+";"21";"22";"23";"24";"25";"26";"27";"28";"29";"2A";"2B";"2C";"-";".";"2F";
"0";"1";"2";"3";"4";"5";"6";"7";"8";"9";"3A";"3B";"3C";"3D";"3E";"3F";
"40";"A";"B";"C";"D";"E";"F";"G";"H";"I";"J";"K";"L";"M";"N";"O";
"P";"Q";"R";"S";"T";"U";"V";"W";"X";"Y";"Z";"5B";"5C";"5D";"5E";"_";
"60";"a";"b";"c";"d";"e";"f";"g";"h";"i";"j";"k";"l";"m";"n";"o";
"p";"q";"r";"s";"t";"u";"v";"w";"x";"y";"z";"7B";"7C";"7D";"~";"7F";
"80";"81";"82";"83";"84";"85";"86";"87";"88";"89";"8A";"8B";"8C";"8D";"8E";"8F";
"90";"91";"92";"93";"94";"95";"96";"97";"98";"99";"9A";"9B";"9C";"9D";"9E";"9F";
"A0";"A1";"A2";"A3";"A4";"A5";"A6";"A7";"A8";"A9";"AA";"AB";"AC";"AD";"AE";"AF";
"B0";"B1";"B2";"B3";"B4";"B5";"B6";"B7";"B8";"B9";"BA";"BB";"BC";"BD";"BE";"BF";
"C0";"C1";"C2";"C3";"C4";"C5";"C6";"C7";"C8";"C9";"CA";"CB";"CC";"CD";"CE";"CF";
"D0";"D1";"D2";"D3";"D4";"D5";"D6";"D7";"D8";"D9";"DA";"DB";"DC";"DD";"DE";"DF";
"E0";"E1";"E2";"E3";"E4";"E5";"E6";"E7";"E8";"E9";"EA";"EB";"EC";"ED";"EE";"EF";
"F0";"F1";"F2";"F3";"F4";"F5";"F6";"F7";"F8";"F9";"FA";"FB";"FC";"FD";"FE";"FF"
:local string $1
:if (([:typeof $string] != "str") or ($string = "")) do={ :return "" }
:local lenstr [:len $string]
:local constr ""
:for pos from=0 to=($lenstr - 1) do={
:local urle ($UTF8toURLe->[:find $ascii [:pick $string $pos ($pos + 1)] -1])
:local sym $urle
:if ([:len $urle] = 2) do={:set sym "%$[:pick $urle 0 2]" }
:set constr "$constr$sym"
:return $constr
:global lastLog
:if ([:typeof $lastLog] != "num") do={:set lastLog 0}
:local tgBot "XXXXXXXXXXXXXXXX:XXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXX"
:local tgChatID "XXXXXXXXX"
:local tgPrefix "\E2\84\B9 MikroTik $[/system identity get name] $[/system resource get board-name]"
:local wtopics "critical|error|warning"
:local utopics "ipsec"
:local mkwd "login failure|logged in|loop|down|fcs|excessive|system|rebooted|ipsec|ike2"
:local ukwd "unwanted|example|phase1 negotiation failed"
:local trim 256
:local id2num do={:return [:tonum "0x$[:pick $1 1 [:len $1]]"]}
:local tgmessg ""
:local emotico ""
:local temp ""
:local tempmsg ""
/log
:foreach item in=[find where (((([$id2num $".id"] > $lastLog) and (buffer=memory)) and (!([:tostr $topics]~"($utopics)"))) \
and \
((([:tostr $topics]~"($wtopics)") or (message~"($mkwd)")) and (!(message~"($ukwd)"))))] do={
:set lastLog [$id2num $item]
:set emotico ""
:local temp [:tostr [get $item topics]]
:if ($temp~"critical") do={:set emotico "\E2\98\A0\20"}
:if ($temp~"error") do={:set emotico "$emotico\E2\9D\8C\20"}
:if ($temp~"warning") do={:set emotico "$emotico\E2\9A\A0\20"}
:set tempmsg [get $item message]
:if ([:len $tempmsg] > $trim) do={:set tempmsg ("$[:pick $tempmsg 0 ($trim - 1)]\E2\80\A6") }
:set tgmessg [$UTF8toURLencode ("$tgPrefix\r\n$[$anydate2isodate [get $item time]] $emotico$tempmsg")]
/tool fetch url="https://api.telegram.org/bot$tgBot/sendMessage\3Fchat_id=$tgChatID&text=$tgmessg" keep-result=no
EDIT 1,2,3 and 4: bugfix
EDIT 5: Separate the two version of the script on 2 posts.
EDIT 6: Log Filter - #28 by rextended - Scripting - MikroTik community forum
EDIT 7: Exclude on default ipsec error messages phase1 negotiation failed, added the possibility to exclude topics regardless are critical or error or warning
(thanks to @S8T8 for the idea)
EDIT 8: Misspell error
EDIT 9: Added the trim parameter to cut the message at wanted length, the default is 256 (thanks to @S8T8 for the idea)
EDIT 10: The trim now ignore the critical / error / warning icons
EDIT 11: Replaced "..." with unicode character 0xE2 0x80 0xA6 "…"
EDIT 12: The "trim" now trim to one less character to add "..." at the end (on this way the message, without considering critical / error / warning icons, are exactly of that length)
Impressive work Rex, thank you very much, really.
I’m away with the family right now, I’ll try it as soon as I can.
BR.
UNIQUE MESSAGE WITH ALL LOGS VERSION:
/system clock
:local string $1
:local constr ""
:local sym $urle
:return $constr
:global lastLog
:local trim 256
:local tgmessg ""
:local emotico ""
:local temp ""
:local tempmsg ""
/log
and \
:set emotico ""
:set tgmessg "$tgmessg$[$anydate2isodate [get $item time]] $emotico$tempmsg\r\n"
:if ($tgmessg != "") do={
:set tgmessg [$UTF8toURLencode ("$tgPrefix\r\n$tgmessg")]
EDIT 1: Log Filter - #28 by rextended - Scripting - MikroTik community forum
EDIT 2: Exclude on default ipsec error messages phase1 negotiation failed, added the possibility to exclude topics regardless are critical or error or warning
EDIT 3: Misspell fixed
EDIT 4: Posted the wrong version of the script
EDIT 5: Posted the correct version of the script
EDIT 6: Added the trim parameter to cut the message at wanted length, the default is 256 (thanks to @S8T8 for the idea)
EDIT 7: The trim now ignore the critical / error / warning icons
EDIT 8: Replaced 3 dots at the end "..." with the unicode character 0xE2 0x80 0xA6 "…"
EDIT 9: The "trim" now trim the message to one less character (on this way, without considering critical / error / warning icons, are exactly of that length with "…" at the end)
Thanks, I hope is error free. I do not have Telegram, but the URL “text” is correctly generated.
If you ignore the date conversion and the correct urlencode, are less lines of code for do the same thing… ![]()
I confirm that your script works perfect, it is much better to work on the last Id.
I love how summarized the code is. Thanks again.
@rextended testing right now, works also for me!
This should be a pinned topic…
Since I never seen at same time critical that is also error or warning on same log, no matter, but I want fix code for this.
from
:if ($temp~“critical”) do={:set emotico “\E2\98\A0\20”}
:if ($temp~“error”) do={:set emotico “\E2\9D\8C\20”}
:if ($temp~“warning”) do={:set emotico “\E2\9A\A0\20”}
to
:if ($temp~“error”) do={:set emotico “$emotico\E2\9D\8C\20”}
:if ($temp~“warning”) do={:set emotico “$emotico\E2\9A\A0\20”}
Thanks, added to my “Fragments of Snippets”:
http://forum.mikrotik.com/t/rextended-fragments-of-snippets/151033/64
Also if I don’t have any knowledge in scripts I applied few edits;
added a dash " - " before a new line of log sent on the text
Example: -
2023-05-28 12:20:46 ether3 link down
2023-05-28 12:21:03 ether3 link up (speed 100M, full duplex)
changed: and !(message~" → and !(topic~"
I fell that is easier for me to exclude topics instead of content of the log. -
it’s possibile (and easy) to have just the time instead of the full date in the text? (Only if is provided by the script, don’t want to waste your time)
Example: -
Have a nice Sunday!
- changed: and !(message~" → and !(topic~"
Nice Idea, I consider that on next version.
But doing that in your way, you can accidentally avoid the reporting of critical / error logs if are critical/error at the same time of your unwanted topic…
- it’s possibile (and easy) to have just the time instead of the full date in the text? (Only if is provided by the script, don’t want to waste your time)
Example:- 12:20:46 ether3 link down
Yes, replace the line
:return “$[:pick $dtime ($vdoff->0) ($vdoff->1)]-$MM-$[:pick $dtime ($vdoff->4) ($vdoff->5)] $[:pick $dtime ($vdoff->6) ($vdoff->7)]”
with what you want, like
:return “$[:pick $dtime ($vdoff->6) ($vdoff->7)]”
sorry guys but i’ve been busy. I’ll try as soon as I have time. but this script left in chat last, send any event log?
Both on post #22 and post #24, choose your preferred version
I tried the script and I adapted it to my needs, and I would say that it works very well.. even if some error alerts are annoying and not very sensible like the ipsec phase 1 which fails when the router fails over, it doesn’t make sense. .how could I do to create a list of phrases that should not be communicated on telegram? this script I understand will also work from version 7.10 with the ISO adaptations of the date and time. Right?
Yes
Both scripts are updated for:
EDIT x: Exclude on default ipsec error messages phase1 negotiation failed, added the possibility to exclude topics regardless are critical or error or warning
Updated! thx
Nice update, this was exactly what I meant!
You mind to spend few words on the last Edit?
Hope to have other suggestion to share.
THANKS!!!
FYI, I'm using it as Scheduler running every 10min.
As I'm not a fan of Telegram I'll check if possible an easy integration with other solutions like Elements (Matrix).
Really? ![]()
Exclude on defoult ipsec ==>> Exclude on default ipsec
Hi @rextended, using the latest version of the script provided, if possible would be nice to have integrated the possibility to exclude some topics but integrate if associated with others to be included, like MikroTik logging settings.
Let me explain a little bit better;
If we include topic “DHCP” a bunch of notifications are sended, the messages “assigned” “unassigned” must be excluded to avoid this.
Excluding topic “DHCP” also exclud the warnings that are not sent.
The possibility to include topics DHCP but not if is !info would be useful.
Make sense? What do you think?
Have a nice weekend!
Hello all, @rextended, someone may will find useful the option to truncate messages, like logs with more than 30 characters are replaced with “…”.
What do you think?
