Log packet via bgp
Dear All,
I have a configuration like this (in real this is the half of the redundant pairs, but it is enough for describe the problem):
myRouter ip1,ip2 -----vlanx------ ip3,ip4 otherRouter
on myRouter there is two ip:
ip1 → base ip
ip2 → vrrp ip
on otherRouter the same two ip:
ip3 → base ip
ip4 → vrrp ip
Between the base ip-s (ip1-ip3) there is a bgp session, which gives a lot of routes for myRouter. So myRouter only gets routes, itself it doesn’t advertise.
On myRouter also there are more static routes which points towards the ip4 of the otherRouter.
I would like to check (log prefered to see hosts information, but packet counts can help too) how much/what kind of traffic goes to/from that direction, that the bgp session gives.
In the /routing filter I could set-routing-mark which leads to a second routing-table and differentiating the traffic at routing level, which errrr maybe can break the traffic.
Is there any idea, how can I mark the traffic, which I could use in the firewall sections?
thank you
I want repaint my house with same color of my friend house, how much paint I need and what color should I buy it?
No answer or sarcastic reply to your question? How to write posts
