hi fellows i was trying to setup an remote access to my server via mikrotik but im facing a password request which is ruining the whole operation, please anyone can tell me how i bypass password request, animated screenshot attached:
when i input the password it logins but i dont need that i need that to be automatic using preshared key
make sure that you copied on the Linux server side, the generated key to the authorized_keys file under the correct linux user home dir (in my case the user is called connect) :
make sure that inside /etc/ssh/sshd config file (or equivalent other distro file) , you have added the source ip of mikrotik client to the AllowUsers row.
following the previous steps, you will succeed to enter ssh server from mikrotik ssh client without any password (100% guarantee at least on my current installed RoS 5.16):
[connect@ROUTER-GREENCOMPUTING] > /system ssh 172.23.1.2 user=connect
Linux connectiviaPBX 2.6.32-24-generic-pae #39-Ubuntu SMP Wed Jul 28 07:39:26 UTC 2010 i686 GNU/Linux
Ubuntu 10.04.1 LTS
Welcome to Ubuntu!
* Documentation: https://help.ubuntu.com/
Last login: Mon Aug 13 01:05:25 2012 from 172.21.1.1
connect@greenComputing:~$
the 1st post was misunderstanding of how ssh key login works when connection ROS to Ubuntu
“/user ssh-key private print” outputs the actual keys I’ve got, ROS to ROS connection done via ssh keys
but what i couldn’t done is ROS to Ubuntu its so hard can you give instructions how i can use default settings of Ubuntu 12 please
as promised here you ahve a working example of sshd_config file used on one of my test server :
root@greencomputing:/etc/ssh# more sshd_config
# Package generated configuration file
# See the sshd_config(5) manpage for details
# What ports, IPs and protocols we listen for
Port 22
# Use these options to restrict which interfaces/protocols sshd will bind to
#ListenAddress ::
#ListenAddress 0.0.0.0
Protocol 2
# HostKeys for protocol version 2
HostKey /etc/ssh/ssh_host_rsa_key
HostKey /etc/ssh/ssh_host_dsa_key
#Privilege Separation is turned on for security
UsePrivilegeSeparation yes
# Lifetime and size of ephemeral version 1 server key
KeyRegenerationInterval 3600
ServerKeyBits 768
# Logging
SyslogFacility AUTH
LogLevel INFO
# Authentication:
LoginGraceTime 120
PermitRootLogin no
StrictModes yes
RSAAuthentication yes
PubkeyAuthentication yes
#AuthorizedKeysFile %h/.ssh/authorized_keys
# Don't read the user's ~/.rhosts and ~/.shosts files
IgnoreRhosts yes
# For this to work you will also need host keys in /etc/ssh_known_hosts
RhostsRSAAuthentication no
# similar for protocol version 2
HostbasedAuthentication no
# Uncomment if you don't trust ~/.ssh/known_hosts for RhostsRSAAuthentication
#IgnoreUserKnownHosts yes
# To enable empty passwords, change to yes (NOT RECOMMENDED)
PermitEmptyPasswords no
# Change to yes to enable challenge-response passwords (beware issues with
# some PAM modules and threads)
ChallengeResponseAuthentication no
# Change to no to disable tunnelled clear text passwords
#PasswordAuthentication yes
# Kerberos options
#KerberosAuthentication no
#KerberosGetAFSToken no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
X11Forwarding yes
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
TCPKeepAlive yes
#UseLogin no
#MaxStartups 10:30:60
#Banner /etc/issue.net
# Allow client to pass locale environment variables
AcceptEnv LANG LC_*
Subsystem sftp /usr/lib/openssh/sftp-server
# Set this to 'yes' to enable PAM authentication, account processing,
# and session processing. If this is enabled, PAM authentication will
# be allowed through the ChallengeResponseAuthentication and
# PasswordAuthentication. Depending on your PAM configuration,
# PAM authentication via ChallengeResponseAuthentication may bypass
# the setting of "PermitRootLogin without-password".
# If you just want the PAM account and session checks to run without
# PAM authentication, then enable this but set PasswordAuthentication
# and ChallengeResponseAuthentication to 'no'.
UsePAM yes
AllowUsers *@172.2.0.0/16,10.10.1.1
