Logo on hotspot page
Hi
I have edited my login,status and logout page, and everything woks(my links to user manager for users,etc). But for some reason my logo is not showing! I put the logo in the /hotspot/img folder with the correct file name(ie the same as in the html code, but its not working!
Anyone know what I am doing wrong?
Try,
wireless logo
Kind regards
B
Hi
Thanks alot, but it is still not working.
Any other ideas?
Double check your file is there and that is the correct name. Capitalization matters as well.
Thanks, I made sure now, the file is there and capitalisation is the same.
Any other thoughts? Should I put a copy of the code here?
Yep. Include the image too
And the output of
/file print
I have attached the files.
Please let me know if there is anything more I should upload.
Thanks for the help!
hotspot.rar (285 KB)
Ok, I took a look, but don’t see the problem.
The wireless image is showing without any problem when I open your login.html
Your /file print isn’t very clear posted on the forum, can you expand the view and post again?
Or use winbox to show it and make a screenshot.
I put the image your provided in the root of the directory you posted and everything worked with this
<body>
<p align="center"><img src="./file.png"><br />
<strong><em>Internet usage Policy </em></strong></p>
I suspect you have either an invalid filename or invalid file path.
