Look for a switch with arm64 and dual boot
The product search filter is horrible is an under-statement.
Looking for a switch with following features:-
  1. ARM64
  2. dual boot
  3. at least 1GB of ram preferably 2GB
  4. License level 5/6
  5. no wireless
  6. cheapest l could get
Conflicting requirements.
No switch will tick 4 or more boxes without hugely going against last point.
Switches with ARM64, 2 results below 500 $:
https://mikrotik.com/product/crs304_4xg_in
https://mikrotik.com/product/crs418_8p_8g_2s_rm
Both come with RouterOs only (level 5).
First has 512 Mb RAM, second 1 GB.
End of search.
Is the RB5009 an option?
Official Mikrotik prices for switches: https://mikrotik.com/products/group/switches
You have to check the best fitting you. Not too many choices but local distributors/sellers could offer better prices or you can real bargains before the end of year.
"I need a switch, I dont care how many ports, their speeds, or switching performance. As long as it has these router specifications."
Why dont you look for a router?
Because they aren't dual boot, point 2 of the list.
A number of switch devices are dual boot SwOS/RouterOS, but they are not ARM64, point 1 of the list.
Loosely devices with ARM64 run RouterOS only, no matter if they are categorized as switches or routers,
Funny as I was expecting dualboot to be able to partition.
@d3lynk, can you give some more insights please?
Could be, of course :slightly_smiling_face:, ambiguous requirement.
Here’s the best way:
  1. Search for “ARM64 switch” + “dual-image” or “dual-boot” in the specs.
  2. Ensure it has ≥1 GB RAM and no wireless.
  3. If you need RouterOS level 5/6 license, focus on MikroTik or RouterBOARD gear.
  4. Compare prices and pick the cheapest device that meets those must-haves.
Want me to find 3 good switches right now with those specs?
Yes, please.
AI reply...
Please leave that sh~t out of the forum.
Thank you for kindly thanking those who responded to you.
Thanks for all the responses. Did go with crs310-8g+2s+…… which it had arm64.
Dedicated routers don’t sufficient number of ports that l needed and or my bandwidth requirement.
Isn't it only ARM32?
Think he tried to say wish...
