We have a Lora 8 gateway with the official MikoTik Lora external antenna which has a 6.5 dBi gain.
Within the Lora device configuration / Antenna Gain section are we supposed to chnage eth fefault setting from 0 to 6.
I’m mainly asking as we seem to have a pretty poor range from the gateway, something just under 1 km where i was hoping for at least somewhere like 3 - 5 km in a fairly urban environment
I am also having questions about external antennas!
with a 3.5dbi antenna what should I put on antenna gain?
(looks like it only accepts an 8 bit integer) “-128 to 127”
I’ve got a MikroTik LR8 LoRa gateway and expected the internal LoRa-antenna connected to the LoRa-module from factory. I played a little bit arround with it and while trying to connect the external antenna I saw that the internal antenna wasn’t connected all the time.
I have terrible range even with the external antenna and now I wonder, if the LoRa-module was damaged by using it without an antenna.
There was no warning on the packaging that the internal antenna is not connected from factory. Does the LoRa-Module has any protection from using it without an antenna or do you think it might be broken? Is there any way to check if the module is broken?
