All,
I’m totally new to mikrotik - more experienced with cisco.
Therefore I started with a small Hex S device (RB760iGS).
After 3 days and reading many online documents I’m lost in setting up router like required.
Plan is to have Hardware connected like this:
Carrier router providing internet access over a bridged port => RB760iGS connected with 1"trunk+tagged VLAN" => cisco access switches
Purpose of the RB760 running on latest stable OS (6.44.1):
Provide appr. 10-15 VLAN each with DHCP-Server
Allow access between VLAN + Access through firewall rules
Generally firewall internet-access
(This was plan to get rid of the Cisco RV130 which is only supporting max of 4 VLAN.)
I could manage mostly all. on the HexS. Major issue for me is, I’m not able to figure out how I can create the DHCP-Servers for different VLAN on the same tagged port.
I tried to add DHCP-Servers to Bridge, ethernet-interface as well on VLAN nothing seems to work finally. Is this a limitation of the router firmware or hardware?
Would appreciate your input or guidence to an example where 10x DHCP-Server/VLAN are used on one tagged/trunk-port.
greetings from
bigquestion
