lost ping randomly
Running MikroTik RouterOS 6.38.5 on RBwAPG-5HacT2HnD.
Got a Canon ip7200 firmware v1.0 (latest).
Printer is connected on 2.4 channel1 (forced to channel1) and ping around 1ms and 900ms and sometime drop off ping..?? why?
Printer is 15 feet away from RBwAPG-5HacT2HnD (ceiling mount 8 feet)
The RBwAPG-5HacT2HnD is default configured in WISP AP.
Thanks!
Is the printer suspend mode enabled?
I had problems with HP Ink jet printers when was connected to wireless, even disabling the suspend mode, the print wasn’t accessible sometimes.
I will never again buy an HP printer. They get stuck in a continuous standby mode where you have to power cycle them to get them to work again.
Sent from my LG-H872 using Tapatalk
Here the ping log from my macbook pro
Last login: Wed Apr 12 20:22:45 on ttys000
MacBook-Pro-de-User:~ user$ ping 192.168.1.7
PING 192.168.1.7 (192.168.1.7): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
64 bytes from 192.168.1.7: icmp_seq=0 ttl=64 time=2012.135 ms
64 bytes from 192.168.1.7: icmp_seq=1 ttl=64 time=1016.236 ms
64 bytes from 192.168.1.7: icmp_seq=2 ttl=64 time=13.500 ms
64 bytes from 192.168.1.7: icmp_seq=3 ttl=64 time=33.257 ms
64 bytes from 192.168.1.7: icmp_seq=4 ttl=64 time=54.402 ms
64 bytes from 192.168.1.7: icmp_seq=5 ttl=64 time=75.284 ms
64 bytes from 192.168.1.7: icmp_seq=6 ttl=64 time=99.123 ms
64 bytes from 192.168.1.7: icmp_seq=7 ttl=64 time=18.547 ms
64 bytes from 192.168.1.7: icmp_seq=8 ttl=64 time=41.393 ms
64 bytes from 192.168.1.7: icmp_seq=9 ttl=64 time=64.366 ms
64 bytes from 192.168.1.7: icmp_seq=10 ttl=64 time=84.351 ms
64 bytes from 192.168.1.7: icmp_seq=11 ttl=64 time=108.741 ms
64 bytes from 192.168.1.7: icmp_seq=12 ttl=64 time=26.006 ms
64 bytes from 192.168.1.7: icmp_seq=13 ttl=64 time=45.486 ms
64 bytes from 192.168.1.7: icmp_seq=14 ttl=64 time=68.214 ms
64 bytes from 192.168.1.7: icmp_seq=15 ttl=64 time=91.461 ms
64 bytes from 192.168.1.7: icmp_seq=16 ttl=64 time=113.143 ms
64 bytes from 192.168.1.7: icmp_seq=17 ttl=64 time=519.759 ms
64 bytes from 192.168.1.7: icmp_seq=18 ttl=64 time=52.324 ms
64 bytes from 192.168.1.7: icmp_seq=19 ttl=64 time=73.909 ms
64 bytes from 192.168.1.7: icmp_seq=20 ttl=64 time=95.402 ms
64 bytes from 192.168.1.7: icmp_seq=21 ttl=64 time=16.377 ms
64 bytes from 192.168.1.7: icmp_seq=22 ttl=64 time=40.117 ms
64 bytes from 192.168.1.7: icmp_seq=23 ttl=64 time=61.762 ms
64 bytes from 192.168.1.7: icmp_seq=24 ttl=64 time=84.880 ms
64 bytes from 192.168.1.7: icmp_seq=25 ttl=64 time=208.674 ms
^C
--- 192.168.1.7 ping statistics ---
26 packets transmitted, 26 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 13.500/196.879/2012.135/415.607 ms
Same delay directly from AP.
