Hello Team,
I am new to Mikrotik routers. I have a router RB5009UG+S+IN. We have multiple WAN connections and we needed to do load balancing so that the 2 ISPs will be getting distributed for the connections.
I have done the configuration based on the tech video from Mikrotik: https://www.youtube.com/watch?v=nlb7XAv57tw&t=858s
The load balancing is working fine. When I check the firewall connections, I can see that connections are distributed between ISP1 and ISP2.
But the problem is when both WAN links are connected to the router, the internet speed becomes drastically slow. Even I won't be able to browse to YouTube or any other websites. If I disconnect 1 WAN link from the router, then the speed will be getting increased.
I will list what all troubleshooting steps which I did so far.
Tried to connect 1 ISP to the router at a time and the speed was good at that time. When both ISPs are connected, speed becomes extremely slow.
Checked the internet speed on both WAN links bypassing the router and the speed was good.
Tried to configure the WAN link to the different interface, but the issue was still the same.
I also came across a forum link where I think the user was similar issue and updated my mangle rules based on the solved comment. But still even after those changes the internet speed is still very slow.
Kindly help me with this issue as I need to get this load balancing working as soon as possible since the internet speed is causing issue for our Cloud Software.
I will share the running configuration below. Note that I have removed 2 default routes with the distance value of 1, since adding that route was slowing down the internet speed.
Also, 4 mangle rules on top were disabled since I am not doing the load balancing now.
Hope someone will be able to check the configuration and help me with what is missing from my end.
Thank you in advance.
[admin@MikroTik] > export
# jan/09/2025 15:08:55 by RouterOS 7.8
# software id = 0I4U-6WY6
# model = RB5009UPr+S+
# serial number = ****
add admin-mac=78:9A:18:95:0B:93 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether2 ] name=ISP1
set [ find default-name=ether5 ] name=ISP2
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.88.20-192.168.88.254
add address-pool=default-dhcp interface=bridge lease-time=12h name=defconf
/routing table
add disabled=no fib name=To-ISP1
add disabled=no fib name=To-ISP2
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp-sfpplus1
192.168.88.0
/ip dhcp-client
add add-default-route=no interface=ISP1
add add-default-route=no interface=ISP2
add address=192.168.88.0/24 comment=defconf dns-server=1.1.1.1,8.8.8.8 gateway=\
192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=accept chain=prerouting disabled=yes dst-address=192.168.8.0/24
add action=accept chain=prerouting disabled=yes dst-address=192.168.0.0/24
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=yes \
dst-address-type=!local in-interface=bridge new-connection-mark=ISP1-Conn \
passthrough=yes per-connection-classifier=both-addresses:2/0
dst-address-type=!local in-interface=bridge new-connection-mark=ISP2-Conn \
passthrough=yes per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting connection-mark=ISP1-Conn in-interface=\
bridge new-routing-mark=To-ISP1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=ISP2-Conn in-interface=\
bridge new-routing-mark=To-ISP2 passthrough=yes
add action=mark-routing chain=output connection-mark=ISP1-Conn new-routing-mark=\
add action=mark-routing chain=output connection-mark=ISP2-Conn new-routing-mark=\
add action=mark-connection chain=prerouting connection-mark=no-mark \
in-interface=ISP1 new-connection-mark=ISP1-Conn passthrough=yes
in-interface=ISP2 new-connection-mark=ISP2-Conn passthrough=yes
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
add action=masquerade chain=srcnat out-interface=ISP1
add action=masquerade chain=srcnat out-interface=ISP2
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
192.168.8.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=\
192.168.0.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp \
src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
dst-address-list=bad_ipv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
protocol=udp
ipsec-ah
ipsec-esp
/system clock
set time-zone-name=Asia/Riyadh
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
