I have the LtAP mini and a the LTE module working nicely with the excellent Traccar project (https://www.traccar.org/) posting OsmAnd messages with https. I originally was trying to use Thingsboard sending JSON messages but after some frustrations with that project I quickly discovered Traccar and got it all working very quickly.
Mitchell,
valid: no
satellites: 0
fix-quality: 0
Did you do it while device is turned off? GPS antenna is an active/powered antenna, connecting it to a live unit can cause damage to the GPS module.
Made sure I plugged it in while powered off, then switched the unit on.
Left it for hours, nothing.
Left it in direct skyview, nothing.
Passive antenna - https://mikrotik.com/product/acgpsa
Forum is not the best place to get indepth technical analysis, make a supout.rif file and email it to support@mikrotik.com, maybe some bigger issue can be seen in the debug info.
Hi, mikrotik gps tracker script https://www.youtube.com/watch?v=cFSEs5wWGTU
www.gpsmap.am gps monitoring server
Script
:local serverURL “https://gpsmap.am/server/api/api_loc.php”
:local fakeImei “123456789123456”
:local SIMslot “0”
:local button “0”
:global isDebug
:put $isDebug - check current state
:set $isDebug “terminal” - log to terminal
:set $isDebug “off” - logging off
Current Debug status
:set $isDebug “off”
:local gpsDateTime
:local lat
:local lon
:local alt
:local gpsSpeed
:local bearing
:local gpsValid
:local sats
:local hdop
:local DateTime
:local outputURL
#Check and set coordinate format and get data from GPS
:if ( [/system gps get coordinate-format ] != “dd”) do={/system gps set coordinate-format=dd}
/system gps monitor once do={
:set $gpsDateTime $(“date-and-time”)
:set $lat [:pick $(“latitude”) 0 7]
:set $lon [:pick $(“longitude”) 0 8]
:set $alt $(“altitude”)
:set $gpsSpeed $(“speed”)
:set $bearing $(“true-bearing”)
:set $gpsValid $(“valid”)
:set $sats $(“satellites”)
:set $hdop $(“horizontal-dilution”)}
:set $alt [:pick $alt 0 [:find $alt “.”]]
:set $gpsSpeed ([:pick $gpsSpeed 0 [:find $gpsSpeed “.”]].“.0”)
:set $bearing ([:pick $bearing 0 [:find $bearing “.”]].“.0”)
Reformating date and time.
:local day [ :pick $gpsDateTime 4 6 ]
:local month [ :pick $gpsDateTime 0 3 ]
:local year [ :pick $gpsDateTime 7 11 ]
:local time [ :pick $gpsDateTime 12 19]
:local DateTime “$year-$month-$day $time”
:set $outputURL (“$serverURL?imei=$fakeImei&dt=$DateTime&lat=$lat&lng=$lon&altitude=$alt&angle=$bearing&speed=$gpsSpeed&loc_valid=1”)
:if ($isDebug = “terminal”) do={
:put $gpsDateTime
:put $DateTime
:put $lat
:put $lon
:put $alt
:put $gpsSpeed
:put $bearing
:put $gpsValid
:put $sats
:put $hdop
:put $serverURL
:put $fakeImei
:put $battVoltage
:put $SIMslot
:put $button
:put $outputURL
/tool fetch mode=http url=“$outputURL” output=none
Really nice example, thanks for sharing the video!
change the port speed
