LTE DYNAMIC PUBBLIC ADDRESS
Good morning, I have some LTEs with a dynamic public IP, I would like to know if it is possible to monitor them on the DUDE portal, do you know if there is a way to do it?
You’d need to enable DDNS in /ip/cloud on the LTE device, then use that DNS name (snXXXX.mynetname.net) in the Dude device configuration. In Dude device, there is setting to say use DNS for IP, instead of IP that needs to be also be set in addition to the DNS name.
i did like you said but right now is it not working. It stays up for 20 seconds and then it goes down and i can’t ping it
You can rarely ping an LTE IP. Cellphone providers are usually not allowing you to connect directly to an LTE IP. You can do outbound traffic but not inbound. You will have to rely on a third party server where your LTE is always connected to relay your inbound message. But then your LTE will have to constantly pull information from that server to get notified.
ok, thank you
