LTE + invalid PIN resulting a locked PIN
Earlier attempts on older ROS to put in an invalid PIN did nothing more that one attempt to set it and fail with a notice into the log, but the v6.15 with LTE moodule it kept on trying that invalid PIN and after 3rd one the SIM was locked - go and find a PUK and a phone.
I seek the restoration of the previous functionality. If the PIN is wrong at the first try, there is no need to commence it numerous times.
Btw: How to enter a PUK code under the ROS?
get off the card into a cellphone and unlock (and disable the SIM request)
If someone read this topics,
this is the solution to unlock the sim after 3 wrong pin.
Warning: after 10 wrong PUK the SIM is broken.
Replace on the example the right numbers on PUK and PIN
/interface lte at-chat lte1 input=“AT+CPIN=PUK,PIN”
You lifesaver, thank you very much!
rOS 7.7, 2023.02.12. OK!
