I tested a little bit today:
LHGG:
created two VLAN interfaces and add them to ether1, VLAN2 is for LTE passthrough and VLAN200 is for management.
On VLAN200 I created dhcp client so LHGG can receive IP address from the router and added VLAN to LAN interface list. (Important, failure to do so will probably lock you out from LHGG)
I deleted old address from LHGG, including pools, dhcp server etc.
Enabled LTE passthrough on VLAN2
ROUTER:
Selected VLAN2 instead of ether on in dhcp client
Added VLAN2 to WAN list instead of ether1
Added ether1 to bridge set it to admit only VLAN tagged, tagged VLAN2 and 200 on that port.
That’s about it, i will include config files here for both devices:
LHGG:
# 2024-09-18 07:38:56 by RouterOS 7.15.3
# software id = xxxx-xxxx
# model = LHGGR
# serial number = xxxxxxxxxxx
/interface lte
set [ find default-name=lte1 ] allow-roaming=no band="" sms-read=no
/interface vlan
add comment=LTE_PASS interface=ether1 name=VLAN2_LTE vlan-id=2
add comment=MGMT interface=ether1 name=VLAN200_MGMT vlan-id=200
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] apn=internet.xxxxxxxx.xx passthrough-interface=\
VLAN2_LTE passthrough-mac=auto use-network-apn=no
/port
set 0 name=serial0
/queue type
add fq-codel-ecn=no kind=fq-codel name=fq-codel-ethernet-default
/queue interface
set ether1 queue=fq-codel-ethernet-default
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=lte1 list=WAN
add interface=VLAN200_MGMT list=LAN
/ip dhcp-client
set allow-remote-requests=yes
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Zagreb
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
ROUTER:
# 2024-09-18 07:39:24 by RouterOS 7.15.3
# model = RB750Gr3
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes
/interface vlan
add comment=WAN interface=bridge name=VLAN2_LTE vlan-id=2
add comment=Local interface=bridge name=VLAN100_LAN vlan-id=100
add comment=Management interface=bridge name=VLAN200_MGMT vlan-id=200
add name=dhcp_pool1 ranges=10.161.100.2-10.161.100.254
add name=dhcp_pool2 ranges=10.161.200.2-10.161.200.254
add address-pool=dhcp_pool1 interface=VLAN100_LAN name=dhcp1
add address-pool=dhcp_pool2 interface=VLAN200_MGMT name=dhcp2
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf frame-types=\
admit-only-untagged-and-priority-tagged interface=ether2 pvid=100
admit-only-untagged-and-priority-tagged interface=ether3 pvid=200
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether1
/interface bridge vlan
add bridge=bridge tagged=bridge vlan-ids=2,100,200
add bridge=bridge tagged=ether1 vlan-ids=2,200
add comment=defconf interface=VLAN2_LTE list=WAN
add comment=Local interface=VLAN100_LAN list=LAN
add comment=Management interface=VLAN200_MGMT list=LAN
add comment="Off bridge" interface=ether5 list=LAN
add address=10.161.100.1/24 comment=Local interface=VLAN100_LAN network=\
10.161.100.0
add address=10.161.200.1/24 comment=Management interface=VLAN200_MGMT \
network=10.161.200.0
add address=172.16.0.1/24 comment="Off bridge" interface=ether5 network=\
172.16.0.0
/ip dhcp-client
add interface=VLAN2_LTE
add address=10.161.100.0/24 gateway=10.161.100.1
add address=10.161.200.0/24 gateway=10.161.200.1
/ip dns static
invalid
invalid
icmpv6
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
ipsec-ah
ipsec-esp
!LAN
/system clock
/system note
/tool mac-server
/tool romon
set enabled=yes
