Hi guys, first of all wanted to say thank you for the great support on this form I have been having over a few months ![]()
I have 2 mirkorik devices connected via trunk and I am passing 2 vlans vlan10 and 20
There is DHCP server on the router 1 for both vlans and the router 2 is just s client
I am planning to get a lte mikrotik device and get it pluged to thу secondary router
Main router it rb4011 and the 2d one is an Audience (it only has 2 ports and 1 is used is a trunk)
My idea is to connect the lte device to the second port of the audience, but how can i do it ?
If i turn on lte passthrough, the managemen will be lost right?
So I would need to create a trunk out of the 2nd port of the Audience same on the lte device, is it correct?
Then let’s say built a point to point network /30
Or shell I instead pass another vlan over the existing trunk let’s say vlan 100 and then use the 2nd ethernet as an access port for that vlan100 plug the lte device in
would that work as passthrough ?
thank you
