Dear MK enthusiasts,
I need your help to increase global performance of LTE systems.
I use SierraWireless MC7710 cards ( 2 ) on a MK routerboard. I can connect to LTE without any issue. LTE connection is very reliable, always up, re-connect in few seconds if I shutdown interface. I can reach easily 20Mbps down, 18Mbps up with a strong -63db signal. I use MAIN and AUX antenna for mimo technologie.
BUT ![]()
When I make a speedtest with my cellphone ( a simple Google Nexus 5 ), same operator, 1m away of my Mikrotik LTE system, I can reach more than 50Mbps down, 40Mbps up. !!! Ouahhh, it make a great difference.
So, I try to play with mikroting settings, but I’m not sure to find the good way :
- MTU for LTE inferace is 1500 : right or must I use something else ? ( and why ? )
- Is there a MSS trick ? ( not sure, there is no encapsulation )
- Other tricks ? I’ve no other idea.
Thanks for your help
Armel
