Is there a way to avoid a problem of MAC address cloning and deny unauthorised access to the internet trough my access point. I do not use pppoe, encryption, hotspot, I just use ARP reply-only and I have created an access-list with permited MAC addresses, but it seems that people get through with MAC address cloning.
yup...
and how to make prevent about it, cause my networks running with dynamic, pppoe, hotspot, and radius AAA as centralize in one interface, now is work fine...over wire and unwire system.
that has it’s own flaws.
whats a username and password worth if anyone can read it?
pppoe makes it a little harder if you limit yourself to ms-chapv2. but if the culprits have lots of spare time then that too wont suffice byitself.
you need to control both ends of any and all links and add some form that can help you gain the trust of the mechanism that maintains the links integrity.
Heh, misunderstanding. What I meant was:
biggest competitors to us giving ethernet tu customers are DSL providers and cable TV companies. Our biggest advantage is local network - DSL and cable TV cannot provide 100Mbps or even 1Gbps between customers.
When U use PPPoE, you kill this advantage and your offer is almost identical to your competitors. Of course U can use PPPoE to internet and ethernet without any tunneling to your network but that couses some problems with p2p software and so on.
If you control the CPEs and set them up for PPPoE you own the whole connection and have full control. Its just a matter of having a good concentrator to terminate all the connections..
