Dear all,
I’m playing with my first Mikortik (RB4011).
I’ve erased the deault configuration and I’ve been following the configuration steps from the wiki: https://help.mikrotik.com/docs/display/ROS/First+Time+Configuration
I’ve my router up and running with a simple and basic configuration (WAN interface + one bridge for the LAN). However I haven’t been able to cofigure the ‘MAC Connectivity Access’ part of the guide.
When I tape into the command line ‘/tool mac-server disable 0;’, it gives me the error ‘bad command name disable (line 1 column 1)’.
In WinBox, when I go to ‘Tools → Mac Server window → Telnet Interfaces’ I don’t see my bridge interface on the dropdown menu. The only thing I see is ‘Allowed interface list: all, dinamic, none, static’.
What should I do?
I’m using the latest stable RouterOS 6.47.7.
Thanks in advance,
