I am looking a good IDS to my net, I know that exits Suricata and Snort, but I would like to use “Maltrail”. I installed on server but I dont know how sent the info from MK to Maltrail’s server. MK tries do it using port 37008 but Maltrail is only listening on http port. Any advice?
BTW, I installed Snort too but I dont know how do that the router’s info go until Snort.
I enabled on “streaming” my IP where its Maltrail (and snort) installed.
I quickly checked out Maltrail documentation. I think you should set up a mirror port and connect your sensor to that port.
Streaming will not help you. Streaming uses tzsp format to send traffic data. Check out https://wiki.mikrotik.com/wiki/Ethereal/Wireshark
Maybe you can use streaming with trafr executable. https://wiki.mikrotik.com/wiki/Mikrotik_IPS_IDS
On this link, there is an example of how to do it with snort.
Interested in this myself. Once my internet gets restored I’m planning on setting up a bunch of these to test in a VM. I’ll let you know what I figure out
Thanks you both. I had installed Snort/Maltrail/Suricata on container openvz, is it a problem?
Suricata give me
23/3/2017 – 08:37:56 - - [ERRCODE: SC_ERR_DATALINK_UNIMPLEMENTED(38)] - Error: datalink type 65535 not yet supported in module DecodeAFP
And when OpenVz container, same output, but with virtual box container if I execute “snort” I receive packets, but with OpenVz container not, with this output:
root@ids:/# snort
Running in packet dump mode
–== Initializing Snort ==–
Initializing Output Plugins!
pcap DAQ configured to passive.
Acquiring network traffic from “venet0”.
ERROR: Cannot decode data link type 113
Fatal Error, Quitting..
I solved to get traffic on server snort from Mikrotik. Server couldn't take traffic from MK because tool "trafr" isn't good installed, you have to download it and install a package, here output:
./trafr
-bash: ./trafr: No such file or directory
The problem is that the trafr program is a 32 bit application and you’re trying this on a 64bit OS without 32bit compatibility libraries. To verify that you can use following command:
I use it creating a dummy interface and replay the tzsp traffic to it with tcpreplay.
modprobe dummy
ip link set name eth10 dev dummy0
ifconfig eth10 192.168.42.42
trafr -s | tcpreplay --topspeed -i eth10 -
python sensor.py
python server.py
and chan chan chan chan…you can use maltrail using eth10
Thanks you for share that, its sounds really good, but I have a problem. I am running under openvz container and I can't load module dummy, do you know how could I do it?
modprobe dummy
modprobe: ERROR: ../libkmod/libkmod.c:507 kmod_lookup_alias_from_builtin_file() could not open builtin file '/lib/modules/2.6.32-openvz-042stab120.18-amd64/modules.builtin.bin'
modprobe: FATAL: Module dummy not found.
I tried loading iptables modules, netfilter... not luck.
