OKNET
March 9, 2017, 10:53am
1
Once switch1-cpu is involved in multiple Vlans for routing purpose, each Vlan can route to WAN by its own gateway
Doing so, also inter-vlan is automatically enabled but this is unwanted.
I’ve got to insert a filter rule on top of my forward ones :
chain=forward action=drop in-interface=all-vlan out-interface=all-vlan
chain=forward action=accept connection-state=established,related
chain=forward action=drop connection-state=invalid
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=pppoe-out1
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=ether24
(first one is the only position that deny inter-vlan traffic)
However, I need some host in a single Vlan to access all hosts in the other Vlans
I’ve tried many rules in many order but host to inter-vlan packets are always dropped: what’s the rights syntax ? where I’m wrong???
Thank you
OKNET
March 9, 2017, 2:53pm
3
Already tried. It doesn’t work.
In this allow rule, packets counter increases while pinging a machine on another vlan but it increases as well on the next rule (the dropping one).
Any idea ?
OKNET:
Any idea ?
Obviously, communication is a two way business. You are getting packets there but not back. Try adding a corresponding dst-address rule:
chain=forward action=accept in-interface=all-vlan out-interface=all-vlan src-address=allo.wed.host.ip
chain=forward action=accept in-interface=all-vlan out-interface=all-vlan dst-address=allo.wed.host.ip
OKNET
March 10, 2017, 7:02am
5
You’re right, I must allow packets in both directions
It works , thanks
Sorry, I missed rule order:
even better:
chain=forward action=accept in-interface=all-vlan out-interface=all-vlan src-address=allo.wed.host.ip connection-state=new
@sid5632 :
I understood that single host should be the one able to connect to the others, that is, initiate the connections and not viceversa; with your suggested ruleset other vlan hosts can initiate connections to allo.wed.host.ip with no restrictions.
OKNET
March 10, 2017, 1:39pm
8
Confirm, new order , it works !
