I’m having a little issue trying to get the CRS326 to work like the Dell Switch. The managed Dell switch has a couple vlans on it but only one is being used from the main router RB1100AHx4 (vlan100) using 10.107.100.x addresses. I can’t seem to get the CRS326 to grab an IP from the main router, the CRS326 bridge is set to grab an ip from the dhcp client that the bridge is on. I’m not sure if I need to make the CRS326 a static IP instead and then make the necessary ports for vlan100.
The Dell Switch managed ports goes as follows in main network closet:
Ports are on vlan100
port 1(Dell vlan1 trunked) goes to port 2 on Mikrotik RB1100AHx4(vlan100-ip addresses 10.107.100.x)
port 4 (Dell) goes to another switch (MT crs326 bridged) in another room from there is a cable run across a parking lot connected by a couple MT GEPR to a Netgear passthru switch that feeds 2 ports on stacked Dell fiber switch OOB
also have 2 ports that feed a OOB on a stacked Dell Fiber switch in our main network closet.
This replacement of the Dell with a CRS326 feeds also 4 cluster hosted servers. I would like it if the new MT switch can easily work but its not going so easily.
Not sure if this is going to help since I'm just trying to get the bridge to accept the vlan100 address 10.107.100 from the main router (Vlan100 ip addresses 10.107.100.10 - 10.107.100.xxx)
add name=bridge
/ip hotspot profile
/port
set 0 name=serial0
add bridge=bridge interface=ether1
add bridge=bridge interface=ether2 pvid=100 (this cable goes into patch panel to other CRS326 in another room)
add bridge=bridge interface=ether23 pvid=100 (cable for OOB on fiber switch)
add bridge=bridge interface=ether24 pvid=100 (cable for OOB on fiber switch)
/ip dhcp-client
add interface=bridge
/system identity
set name=xxxxxxxxxxxxxxxxxxxx
/system note
set show-at-login=no
/system routerboard settings
set boot-os=router-os enter-setup-on=delete-key
More than likely the remaining ports will be Vlan100 on the CRS326
Dell Switch ports:
port 1 - truck, tagged (vlan1) to port 2 on main router
port 3-39,41-42 (untagged) (41-42 to OOB of fiber switches) Vlan100
First of all why the heck are you paying for and using managed switches if you just have one vlan, aka one flat network.
Big waste of money and time configuring… and even have a second CRS326…
In any case not interested in supporting such a whacko concept, but will provide a hypothetical.
Base VLAN or Trusted VLAN will be vlan11 192.168.11.11/24 coming from RB1100
VLA100 will be the HOUSE VLAN and vlan200 will be guest vlan
( no idea what cable to OOB means, so ports not included in example )
add name=bridge vlan-filtering=no { change to YES as last step in config }
interface ethernet
set [ find default-name=ether20 ] name=OffBridge20
/interface vlan add interface=bridge name=vlan11 vlan-id=11 comment=“base or trusted subnet from RB1100”
add name=TRUSTED
/interface list members
add interface=vlan11 list=TRUSTED
add interface=OffBridge23 list=TRUSTED
/ip hotspot profile
/port
set 0 name=serial0
add bridge=bridge ingress-filtering=yes frame-types=admit-only-vlan-tagged interface=ether1 comment=“trunk from RB1100”
add bridge=bridge ingress-filtering=yes frame-types=admit-only-vlan-tagged interface=ether2 comment=“trunk to second CRS326”
add bridge=bridge ingress-filtering=yes frame-types=admin-only-priority-and-untagged interface=ether10 pvid=100
add bridge=bridge ingress-filtering=yes frame-types=admin-only-priority-and-untagged interface=ether11 pvid=100
add bridge=bridge ingress-filtering=yes frame-types=admin-only-priority-and-untagged interface=ether12 pvid=200
add bridge=bridge ingress-filtering=yes frame-types=admin-only-priority-and-untagged interface=ether13 pvid=200
set discover-interface-list=TRUSTED
/interface bridge vlan
add bridge=bridge tagged=bridge,ether1,ether2 vlan-ids=11
add bridge=bridge tagged=ether1,ether2 untagged=ether10,ether11 vlan-ids=100
add bridge=bridge tagged=ether1,ether2 untagged=ether12,ether13 vlan-ids=200
/ip dhcp-client
add address=192.168.11.11 interface=vlan11 network=192.168.11.0 comment=“CRS326 address on base vlan”
add address=192.168.20.1/30 interface=OffBridge20 network=192.168.20.0
set server=192.168.11.1
add dst-address=0.0.0.0/0 gateway=192.168.11.1
/ip ne
/system identity
/system note
/system ntp client
set enabled=yes mode=manycast
/system ntp client servers
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=TRUSTED
First thing, enter config, remove ether20 from bridge, give ether20 a new name and IP address and add to LAN interface list and later to TRUSTED interface list during adjustments.
Simply plug laptop into ether20 with IPV4 settings 192.168.20.2 and you can safely configure from there…
Basically all three vlans are created on the RB1100 and flow into CRS326 on a trunk port and all three flow out the trunk port to the next switch presuming both v100 and v200 are required…Regardless vlan11 is required as all smart devices aka next 326 will get its IP address on vlan11 subnet etc…
Guess I should have rephrased it from Managed-to-Managed inhouse. We manage all the Dell Switches and Mikrotiks.
The OOB means Out-of-Band. Our out of band network is the Vlan 100 from the main router, So this CRS switch will be strictly using the 10.107.100 network on all ports. Sorry if I confused you.
The Dell Switch is only using 4 ports on it and it’s so old that my boss wants to replace it with a CRS326 and has given me the chore to make it work like the Dell.
Anything simple would do. I can draw up a map if that works too of what I’m trying to do.
The default for Mikrotik bridge ports, including the internal bridge-to-CPU port, is VLAN 1 untagged. Many of the default settings do not appear in /export so this is not immediately obvious.
If you have multiple connections between switches for separate regular and OOB management traffic then spanning tree may be blocking ports as you can only have one active link between switches. The default RSTP has no understanding of VLANs so whilst having two links for non-overlapping groups of VLAN IDs would not cause a loop on of the links will be disabled from passing traffic.
