Mangle
Hello everyone,
I have a Mikrotik router as vpn server with 3 different public IP addresses and clients are connecting to it via different protocols ( pptp and l2tp ) using its main IP.
I want l2tp clients send/receive through route#1 and pptp clients through route#2.
I heared I should use mangle->prerouting, but I’m not sure which action should I use ( mark routing or mark packet) that can identify l2tp from pptp. I would appreciate any helps.
Hi
You have to use mark routing with the l2tp client ip’s and mangle rule another mark routing with the pptp client ip’s so you can go to ip/route and add l2tp mangle in the route1 and pptp mangle in the route 2 or what ever you want to do
Hello and thank you for the reply. I will try this solution.
