Mantbox AX 15s to SXTsq5ac Station bridge mode not able to connect if i try to connect station pseudobridge its connect but not able to dial pppoe connection i also try STP mode none, pls help
hello can anyone help me for this issue
Install wifi-qcom-ac package on SXTsq5ac. Then you can use station-bridge with mAntBox ax.
Compatibility matrix:
Wifi 4-address mode (station bridge) between wifi-qcom and wifi-mediatek - #11 by jaclaz
not able to install i think device not support qcom-ac wireless…plz help or suggest me how to install
Check the exact model, see:
SXTsq5 as CPE to mANTBox ax 15s
Thank You So Much Brother, Got Install in SXTsq5ac QCOM-AC driver now working Fine With mantbox 15AX…Gratefull to YOU……..Thanks Again
SXTsq5ac ARM, Station mode work only with router mode or station-pseudobridge connect but not work with multiple client with pppoe dial, Got MAC error device not pick real mac address..now what next… thanksss.
If you have on both devices now wifi-qcom or wifi-qcom-ac drivers, station-bridge (which is what you want, not station) should be working.
With one device set as AP and the other one set as station-bridge the effect should be that of a "wireless wire" connection, i.e. a transparent bridge, this is how devices sold in pairs as "wireless wire" are set.
Maybe you need something else, you should post what you are trying to do and the configuration of the two devices involved, instructions here:
Brother i have mantbox 15ax as a AP i want to connect sxtsq5ac station bridge with Mantbox before when driver install wireless in sxtsq 5ac that not work now when i install qcom-ac driver should work but one problem still is goin on superchannel not set its fail to select full channel support not showng like mantbox 15ax what should i do now
You know that you are mentioning superchannel only now, at post #10?
Follow given advice? ![]()
