MAP-E(RFC 7597)
hello there,
this post is first time for me in this forum.
i am wondering if mikrotik is planning for the future to implement:
RFC 7597(Mapping of Address and Port with Encapsulation)
reason why i am asking - i currently evaluating HW/SW for acting as an home router.
you may not know some of Internet service provider in Japan already provide MAP-E solution long time ago to get internet connection more smoothly than pppoe connection.
thanks for fast responding
I would like to know too.
It looks like RB4011iGS+5HacQ2HnD-IN supports it.
Do you have a specific use case in mind you need this for?
My ISP requires MAP-E support to use my very own box instead of their GPON/EPON.
https://www.iliad.it/offerta-senza-iliadbox.html#modem-compatibility
Okay, got it!
Your ISP is a pure IPv6 provider, so you need a tunnel for the IPv4 traffic. Yes, it’s doable using the IPIPv6 tunneling in ROS which is supported by any Mikrotik Router. Just follow the instructions in https://www.iliad.it/docs/VoIP/Guida_Mikrotik_e_VoIP.pdf
Does this mean that any Mikrotik box running RouterOS is ok?
Yes, you can use any MikroTik router other than just the RB4011. Iliad likely recommended it because of the SFP+ port, but you can get the RB5009, which is more powerful for a similar price.
I would then suggest mikrotik pre-sales and product marketing people to start talking (more) to ISPs as this would create an extra channel.
Yeah, there is obviously room for improvements.
