Hello
I need a little help to solve my problem.
I’m new to mikrotik programming so I used only the quick set option.
So I would like to connect my Map Lite ap to my main router via wireless and use the MapLite ap ethernet port to connect my IP cam with cable.
I can’t make it work. I can’t see my camera on the network.
My main router ip is: 192.168.1.1
My Map Lite ip is: 192.168.1.6
Here is my config:
# jan/02/1970 00:04:00 by RouterOS 6.45.7
# software id = B1C4-AIEZ
# model = RouterBOARD mAP L-2nD
# serial number = 95DA0A9E17D8
add comment=defconf name=bridge
set [ find default-name=ether1 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
disabled=no distance=indoors frequency=auto mode=station-pseudobridge \
ssid=ip-cam wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk group-ciphers=\
tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik \
unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=1234567 \
wpa2-pre-shared-key=1234567
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge interface=ether1
add address=192.168.1.0/24 comment=defconf interface=wlan1 network=\
192.168.1.0
/ip dhcp-client
# DHCP client can not run on slave interface!
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
ether1
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.6 name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/tool mac-server
/tool mac-server mac-winbox
First, either use a static address on your map or use a dhcp client, not both.
Also in your IP addresses, the address 192.168.1.0/24 is wrong. That is the network address. If you want to set it static then add 192.168.1.6/24 as an address.
Besides that, since i guess you want to have 1 network, then delete all the settings in the map that have to do with firewall, nat, dhcp server etc.
Bridge the wireless interface with the ethernet port and assign the adress above in the bridge it self.
Most important, did the map connected to the router ?
have you used in Quickset the “CPE” setup? That is the one to be used.
Your config is an AP one.
LAN interface list: WLAN0
WAN interface list: ETH0
This should be the opposite
I would suggest you use the CPE quickset, scan for the Wifi signal and connect to it.
Then decide if bridge or router mode. (in theory both should work, as long as IP range on map is not the
same as on your main AP). At least to start with either mode should be enough.
[]No I can’t see my camera on my network (if I plug it to my map)
[]Yes the camere has a static IP address
[]No I can’t ping my camera
[]Yes I tried the CPE option
I did the same as you wrote.
This is my latest non working config.
Do you see any major syntax error in my config?
You could try station-pseudobridge-clone with your cam’s MAC address as station-bridge-clone-mac parameter.
Just to be 100% sure: your main router is not running routerOS, right?
Please provide more details.
Is the IP address of the camera in the same subnet ?
Also, you used quick set with an already configured router ? I would reset the whole config now if i were you.
Did the map establish a connection with the router ? Do you see the R flag ?
Yes my Ip cam details are: 192.168.1.71 / 255.255.255.0
I reset the map couple of times.
Which type of reset do I need? It has 3. opinion:
Hold this button during boot time until LED light starts flashing, release the button to reset RouterOS
configuration (total 5 seconds)
Keep holding for 5 more seconds, LED turns solid, release now to turn on CAPs mode (total 10
seconds)
Or Keep holding the button for 5 more seconds until until LED turns off, then release it to make the
RouterBOARD look for Netinstall servers (total 15 seconds)
If you have no clue what you do on routers, Quickset is a good solution to get you going!
Once done, don’t touch it anymore and make adjustments only within the winbox settings…
I would try the CPE STA mode under Quickset. as it will adjusts all major parameters correctly for what you need,
a Wifi dongle basically.
Then you can see if you need a bridge instead of router, NAT etc.
