is there any plan to introduce newer / refresh mAP models with 2.4 and 5 Ghz WiFi?
Everyone’s hoping for it but Mikrotik does not have the habit of releasing info prior to effective product announcement.
Personally I am using hAP AX Lite LTE as replacement for mAP already for some weeks.
Pretty happy with it.
a dual band mAP with SIM slot for LTE would be fantastic or two versions, one without LTE SIM and one with LTE SIM, perhaps even physically slightly larger but please Mikrotik don’t abandon these two excellent products!!! I’ve used a lot of them in tight spaces
In my view, the biggest selling point for a new mAP should be a single USB-C connection, which serves as power supply and which is also showing up as a network interface on my laptop.
As I use my current mAPlites mainly as mobile devices, capable of extending the range of bad WLAN networks. LTE is not always an option.
I even use them with PoE adaptors. I am sad this option seems to have been completely dropped by MT.
The 2 PoE plugs with 2 mAPlites could provide a way to have Wifi behind a concrete wall.
The whole thing was barely noticed by anyone, not needing much cabling or any additional holes in a ceiling/wall.
It´s easy to install/remove, where I need it.
It’s the PoE passthrough that’s handy in mAP…hope that’s not lost-in-translation. The current mAP’s don’t run ZT or BTH… so also hope any new versions are ARM.
Now a “pro” version of hAPax-Lite-LTE6[-NA] work too. e.g. “pro” == external SMAs for LTE and PoE “passthrough” (in and out).
To be honest, for the over 2 years I have that mAP device, I never had to use the POE-in functionality.
Sometimes when I wanted to, yes (when I was too lazy to get out the PSU
) but never because I had to.
I read cases left and right about others using it much to their favor, so I get it is useful. Just not for me.
Adding POE in/out to AX Lite could maybe solve that gap. I would keep the 4 Gb ports however (already had quite some fun with that and also with mAP I ran a couple of times in some cases where I had to add a dumb switch just to have 2 or 3 extra ether ports).
But then we come once again to the thermal restrictions on the package …
X-mas is when ? ![]()
Well, normis seems like a fan of mAPs too:
hAPaxLite form factor even fit there…
Ok, but THAT example was even more ingenious because of the use of the usb port to power other stuff. Never thought of that.
