rriley
April 28, 2026, 5:58pm
1
Hello I have 200 devices that I wan to control via ACL and MAC ADDRESS to assign VLAN IDS. What is the maximum amount of ACL I can create on The MikroTik CSS326-24G-2S+RM running SwOS.
Rolando
SwOS is for simple L2 deployments. Unfortunately, the CSS326-24G-2S+RM isn't going to work for what you want it to.
SwOS has a software limit of 32 ACLs, so that isn't an option for you, and SwOS does not support 802.1x.
Here are some threads to read:
I have a question about SwOS, in the specifications for Switches with SwOS you can find it under the item
Access Control List - Up to 32 ACL rules (limited by SwOS)
What exactly is limited there.
Does this mean that I can only share 32 MAC addresses for one port? (All locks except those on the whitelist.)
Or can I create 32 lists in which I can store as many MAC addresses as I want that I can enable on the ports.
Concrete case:
I have several offices with one switch each. All emplo…
Hello @all,
Today I read an articlet in the internet about dynamic VLAN. It seems to be what I am looking for.
I understand how dynamic VLAN works and what has to be implemented.
No I have a question regarding my CSS326-24G-2S+RM. How do I have to configure the CSS326-24G-2S+RM to activate/use dynamic VLAN? Is it just to configure each VLAN ID to every port?
Please give advice. Thank you very much for your help.
Regards
Thorsten
I live in a two story apartment. I bought ccr2004 to create vlan based network and route them. I do not have proper ethernet infrastucture in my home. I use gigabit powerline adapters to connect rooms. I wanted to create dynamic vlans based on mac id of the devices with user manager. I am currently distributing ip and control wifi network based on mac id of the devices via user manager. I am currently using a flat network with C class network address. I would like separate the network into vlan…
