Maximum Speed from Cache (Web Proxy)
I have RO 2.9.29 with Hotspot and Web Proxy enabled.
Can any one help me to bypass (TX/RX) limitation in Hotspot User Profile when the request can be served from the cache (web Proxy).
Regards
Adnan
It can’t be done with the proxy integrated in to MT. Look up ZPH (Zero Penalty Hit) patch for Squid proxy and it will allow you to do this on a standalone proxy server. Where in Baghdad are you?
you can’t, with cache (web proxy) integrated in Mikrotik as far as I know…you may use a seperate Unix or Linux computer with squid proxy installed in…and tune it .
you may use queues with burst in user’s profile and that’s all.
all we have is burst-limit and time for that issue.
i have one suggestion, not verified :unamused:
you can redact burst-limit be as big as you want, add parent-proxy behind MT box and add (STATIC) queues with no limit if source is that parent proxy.
next, add on_login script for user’s profile that moves static rules up (respectivelly, dynamic rules goes down).
we use such a scheme like that with file severs in DMZ. works fine. but with proxy I have never test it.
goodluck,
C. G.
