measure vswr
Hiall.
It is possibile to read the vswr somewhre in a radio ?
Or there are cheap systems to do this in 5GHz ?
thanks
it’s not possible to measure this with a wireless card, but you can use other equipment like mentioned here:
http://forum.mikrotik.com/t/how-to-measure-antenna-gain/34738/1
Thank you, but 20K euro is not properly as I call cheap !! :wink:
I know that a vector analyzer is the answer, but I ask if there is a dedicated hardware (1K euro) to do this.
maybe this? http://www.gnswireless.com/PM-2458.htm
no idea if it works
thanks.
does someone used this stuff ?
or does someone knows someting of similar (also surplus)?
thanks
