However if you want to force MT to use one link more then other, for example WAN4, you can add more PCC lines but assigning the same two marks to a specific link , something like
Thanks for reply. Have actually got a setup with 8 lines balanced using PCC, understand what you say. If you have a look at your total data used you will notice that the two with same speed is more or less equal. Unfortunately restarted router Monday but data sines then for each interface used is 5.2G, 1.3G, 5.4G, 3G, 4.7G 3G, 7.8G, 7.3G. From this you can notice that the lines is not used equal. After a month the difference is between 50Gig to 70 Gig It appears to me as though the last lines in the PCC group uses less traffic. I know you can manually assign a user to a link, but this is why u use PCC to do it automatic and it does a decent enough job, would just like a better balancing job.
The pcc method on the wiki is suitable. Having a mobile service rather than ethernet doesn’t make much difference, your wans would probably be ppp rather than ether.
