Hi.
I would kindly ask for advice.
I have one master Mikrotik router with DHCP server and PPPoE connection to my ISP. I would like to install more wired Mikrotik APs on different zones the way users won’t have to switch SSID when switching zones.
I was testing it with 2 mikrotik routers having SSID set exactly the same, using a fixed frequency (not auto). I was downloading a file and switching the zones and monitoring the traffic everything was perfect. Trafic moved from one mikrotik to another smoothly and download wasn’t stopped. I’m not sure if that’s the correct way to do it?
Thank you
Br,
Dali
