Mesh vs. Separate APs (yet another handoff discussion)
I have two wired APs, ap1 and ap2, connected to a router and configured on the same SSID with different channels. Performance is great, and I’ve optimized power to ensure coverage is appropriate. Handoff still sucks. When you travel from one to the other, we’re talking 1-3 seconds of chaos in the era of Teams calls.
I was way happier with the handoff on my previous Google Wifi mesh, and the performance was sufficient. Those endpoints weren’t wired, though, hence the performance hit. Can I run a mesh with wired endpoints like I have and thus get both the performance of a low latency direct backhaul, and the zero handoff of a mesh?
Is there some other option?
You are looking for 802.11r/k/v, for that you need to set up fast transition and steering.
Properties related to 802.11r fast BSS transition only apply to interfaces in AP mode. WiFi interfaces in station mode do not support 802.11r.
For a client device to successfully roam between 2 APs, the APs need to be managed by the same instance of RouterOS. For information on how to centrally manage multiple APs, see > CAPsMAN
What hardware are you using? To get the 802.11 k/r/v, you need to run the wifi wave2 drivers. And use CAPsMAN.
Interesting, I didn’t know about this! I’m using CAP AX (for the APs) and I have a CCR2004 for my network core router. I’ll read up on this protocol, thanks. The only real concern I have is capsman, since honestly, it’s always been more trouble than it was worth, but perhaps that can be overcome.
So I do use the station bridge mode APs in a couple places, to get ethernet jacks where there is no drop. Can I implement 802.11k/v and have the benefits without 802.11r? Station bridge mode still works with k/v?
Update:
I finally had a moment to implement steering and fast transition, and it works great. Wonderful resolution, extremely robust handoff. To help others, here’s the configuration which worked for me (I have three APs and a CCR2004 router running capsman).
# 2024-07-10 20:45:50 by RouterOS 7.15.2
# software id = CWU8-WMJ4
# model = CCR2004-16G-2S+
# serial number = (serial)
add name=bridge1 port-cost-mode=short
set [ find default-name=sfp-sfpplus1 ] advertise="10M-baseT-half,10M-baseT-ful\
    l,100M-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full,1G-baseX,2.5\
    G-baseT,2.5G-baseX,5G-baseT,10G-baseT,10G-baseSR-LR,10G-baseCR"
set [ find default-name=sfp-sfpplus2 ] advertise="10M-baseT-half,10M-baseT-ful\
add name=WAN
add name=LAN
/interface wifi datapath
add bridge=bridge1 disabled=no name=datapath1
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disable-pmkid=yes disabled=no ft=\
    yes ft-over-ds=yes group-encryption=ccmp group-key-update=1h name=sec1 \
    wps=disable
/interface wifi steering
add disabled=no name="Hector Steering" neighbor-group=dynamic-Hector-5518dcee \
    rrm=yes wnm=yes
add disabled=no name="Florry Steering" neighbor-group=dynamic-Florry-5518dcee \
    rrm=yes wnm=yes
/interface wifi configuration
add channel.band=5ghz-ax .reselect-interval=1h .skip-dfs-channels=10min-cac \
    country="United States" datapath=datapath1 disabled=no name="Hector 5GHz" \
    security=sec1 security.ft=yes .ft-over-ds=yes ssid=Hector steering=\
    "Hector Steering" tx-power=15
add channel.band=2ghz-ax .reselect-interval=1h datapath=datapath1 disabled=no \
    name="Florry 2GHz" security=sec1 security.ft=yes .ft-over-ds=yes ssid=\
    Florry steering="Florry Steering" tx-power=15
add name=dhcp_pool0 ranges=10.62.14.128-10.62.14.190
add address-pool=dhcp_pool0 interface=bridge1 lease-time=1w1d name=dhcp1
/ip smb users
/port
set 0 name=serial0
set 1 name=serial1
/system logging action
add email-to=(email) name=email target=email
add bridge=bridge1 interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether4 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether5 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether6 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether7 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether8 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether9 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether10 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether11 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether12 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether13 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether14 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether15 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether16 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=sfp-sfpplus1 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=sfp-sfpplus2 internal-path-cost=10 path-cost=10
set udp-timeout=10s
set discover-interface-list=all lldp-med-net-policy-vlan=1
/ipv6 settings
set disable-ipv6=yes
/interface detect-internet
set detect-interface-list=all
add interface=ether1 list=WAN
/interface wifi capsman
set ca-certificate=auto enabled=yes interfaces=bridge1 package-path="" \
    require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=\
    "Hector 5GHz" slave-configurations="" supported-bands=5ghz-ax
    "Florry 2GHz" supported-bands=2ghz-ax
add address=10.62.14.1/24 comment="LAN range" interface=bridge1 \
    network=10.62.14.0
/ip arp
add address=10.62.14.42 interface=bridge1 mac-address=98:06:3C:24:AB:C9
/ip cloud
set ddns-enabled=yes ddns-update-interval=20m
/ip dhcp-client
add interface=ether1 use-peer-dns=no use-peer-ntp=no
add address=10.62.14.0/24 dns-server=94.140.14.49,94.140.14.59 domain=\
    (domain) gateway=10.62.14.1 ntp-server=10.62.14.1
set servers=94.140.14.49,94.140.14.59
/ip smb shares
set [ find default=yes ] directory=/pub
/system clock
set time-zone-autodetect=no time-zone-name=America/New_York
/system identity
set name=rtr1
/system logging
add action=email topics=critical,warning,account
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
/system ntp client servers
add address=0.pool.ntp.org
add address=1.pool.ntp.org
add address=2.pool.ntp.org
/system routerboard settings
set auto-upgrade=yes enter-setup-on=delete-key
Additionally, to answer my own question earlier, I retain the ability to use station-bridge clients, which is important for my setup. They work just fine after this implementation.
