Dear Nathan,
Mikrotik have experience but am new to MetaRouter, Might me some manual or procedure to virtualize asterisk on mikrotik, I’m studying to propose as a topic for my college thesis, Greetings from Ecuador
Dear Nathan,
for this - you have to have your own built OpenWRT and then you can make binaries of your liking following OpenWRT documentation on how to create binaries for flavor of OpenWRT you have built. (Package building)
@mattijs: Could you provide your patches for backfire r33081 and kernel 2.6.32.61 please. I downloaded the source from openwrt and adopted the patches. Compilation is ok but I can’t start the image.
Thanks! Dirk
Linux version 2.6.32.61 (dirk@obelix) (gcc version 4.3.3 (GCC) ) #1 Sun Dec 22 11:
56:37 CET 2013
CPU revision is: 0001800a (MIPS 4Kc)
Determined physical RAM map:
User-defined physical RAM map:
memory: 01800000 @ 00000000 (usable)
Initrd not found or empty - disabling initrd
Zone PFN ranges:
Normal 0x00000000 -> 0x00001800
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0x00000000 -> 0x00001800
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 6096
Kernel command line: init=/etc/preinit console=hvc0 board=vm mem=24M
PID hash table entries: 128 (order: -3, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Memory: 20816k/24576k available (1952k kernel code, 3760k reserved, 295k data, 128
k init, 0k highmem)
Hierarchical RCU implementation.
NR_IRQS:128
console [hvc0] enabled
Calibrating delay loop... 418.81 BogoMIPS (lpj=837632)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
bio: create slab <bio-0> at 0
Switching to clocksource MIPS
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
Unhandled kernel unaligned access[#1]:
Cpu 0
$ 0 : 00000000 0000006b 00000000 00000000
$ 4 : c01107a0 a1700000 00000000 c0c68d08
$ 8 : 10008201 1000001e 00000000 c0c68cb0
$12 : 00000000 c032ba98 c03276bc 00000000
$16 : 8c430000 c0c17de8 c0360000 00000000
$20 : c033aaf0 00000000 00000000 00000000
$24 : c0c68d08 c0119ac0
$28 : c0c16000 c0c17dc0 00000000 c0101460
Hi : 00000000
Lo : 00000000
epc : c01107b8 0xc01107b8
Not tainted
ra : c0101460 0xc0101460
Status: 10008203 KERNEL EXL IE
Cause : 00000010
BadVA : a1700000
PrId : 0001800a (MIPS 4Kc)
Modules linked in:
Process swapper (pid: 1, threadinfo=c0c16000, task=c0c15938, tls=00000000)
Stack : c032bb48 c01429a4 00000082 00000000 c0c04500 c03521c8 c03522e0 c0360000
00000000 c0101460 c0328bc0 c0142ec4 c0c13e10 00000000 c0c6b880 00000000
00000000 0000006b a1700000 a0000000 a1700000 00004000 01703fff c0c68d08
c032769c c02fa08c 00000000 c0c68cb0 00000000 c032ba98 c03276bc 00000000
c03521c8 c03522e0 c0360000 00000000 c033aaf0 00000000 00000000 00000000
Call Trace:[<c01429a4>] 0xc01429a4
[<c0101460>] 0xc0101460
[<c0142ec4>] 0xc0142ec4
[<c033aaf0>] 0xc033aaf0
[<c0119ac0>] 0xc0119ac0
[<c012a484>] 0xc012a484
[<c033ab20>] 0xc033ab20
[<c033ab2c>] 0xc033ab2c
[<c033aae0>] 0xc033aae0
[<c0109610>] 0xc0109610
[<c01de6fc>] 0xc01de6fc
[<c0155314>] 0xc0155314
[<c0334348>] 0xc0334348
[<c01b4e50>] 0xc01b4e50
[<c010af94>] 0xc010af94
[<c0334264>] 0xc0334264
[<c010af84>] 0xc010af84
Code: 00431024 14400063 00000000 <88b20000> 98b20003 24020000 14400051 000000
00 08044203
Disabling lock debugging due to kernel taint
Kernel panic - not syncing: Attempted to kill init!
[/size]
New build Kamikaze 18961 - image, packages tree, config
Default root password: master
eth0 is preconfigured to use DHCP
New requested packages: rsync, stunnel, quagga, srelay
MIPS:
http://openwrt.wk.cz/kamikaze/openwrt-mr-mips-rootfs-18961.tar.gz
CONFIG MIPS:
http://openwrt.wk.cz/kamikaze/config-kamikaze-mips-18961-20131227
PACKAGES:
http://openwrt.wk.cz/kamikaze/packages/mr-mips/
PPC:
http://openwrt.wk.cz/kamikaze/openwrt-mr-ppc-rootfs-18961.tar.gz
CONFIG PPC:
http://openwrt.wk.cz/kamikaze/config-kamikaze-ppc-18961-20131227
PACKAGES:
http://openwrt.wk.cz/kamikaze/packages/mr-ppc/
Excellent news liquidcz!!!
Any posibility of include zabbix_proxy 2.0 in repository?
I tried to compile without success, my compiler skills are not very good.
Thanks for your effort!
Thanks liquidcz. Do you have any news on stability?
Thank you liquidcz. I have no problems running this image but I can’t change the IP address from DHCP to static. When I click save, I see new values, but when I reboot the router it goes back to DHCP.
I’m afraid that I can only add zabbix 1.6, which is officially in Kamikaze feeds.
liquidcz:
New requested packages: rsync, stunnel, quagga, srelayThanks liquidcz. Do you have any news on stability?
Stability? Did you mean those problems with occasional reboot?
If you are using web administration, after clicking “Save Changes”, you still have to click on the “Applay Changes” at the bottom of the page.
bysard:
ty
LeoCombes:
liquidcz:
New requested packages: rsync, stunnel, quagga, srelayExcellent news liquidcz!!!
I tried to compile without success, my compiler skills are not very good.Thanks for your effort!
Surely, the same is going to happend with other packages, soon. They will be outdated.
Can I run a latest version of the openWRT (Attitude Adjustment) in the routerboard? Or is not possible or technically complicated?
Thanks.
Hello.
liquidcz: can you add packages: minidlna, kmod-usb-uhci, kmod-usb-ohci, kmod-usb2, kmod-usb-printer, p910nd
Thanks a lot (vďaka
Hello, please add print server (printer support) to metarouter. I tried install cups, but it not works.
Thanks!
Thanks!
How do you intend to push USB to metarouter?
Hi. I am not developer of this system and don’t know.
But I see two ways:
**Topic with request http://forum.mikrotik.com/t/add-print-server-printer-support/74629/1
It was a retorical question and the answer is no, you can’t. You can only share ether devices with metarouter.
I just create new repositories for Backfire 10.03.1 build 29592 + ALL packages
OpenWrt milestone info: https://dev.openwrt.org/milestone/Backfire%2010.03.1
Modifications:
MIPS:
http://openwrt.wk.cz/backfire/mr-mips/openwrt-mr-mips-rootfs.tar.gz
CONFIG MIPS:
http://openwrt.wk.cz/backfire/mr-mips/config-mips-backfire-29592
PACKAGES:
http://openwrt.wk.cz/backfire/mr-mips/packages/
PPC:
http://openwrt.wk.cz/backfire/mr-ppc/openwrt-mr-ppc-rootfs.tar.gz
CONFIG PPC:
http://openwrt.wk.cz/backfire/mr-ppc/config-ppc-backfire-29592
PACKAGES:
http://openwrt.wk.cz/backfire/mr-ppc/packages/
Enjoy!
Does it work in rb2011 with ros 6.9 or 6.10?
Sent from Android by Tapatalk.
Works, very well! ![]()
Thank You, liquidcz!
