MGMT vlan dhcp
Hi everyone!
I’m currently deviding my network in multiple vlans. I used the following resource to set up vlans http://forum.mikrotik.com/t/using-routeros-to-vlan-your-network/126489/1 This all seems to be working smoothly. However I came across one issue: in the router config he creates a dhcp server for the management/base vlan. I found this interesting since then I don’t have to set manual IP’s to all my switches and other networking equipment for management access.
When I attach a switch to my router, it can’t get an ip addres and I can’t seem to figure out why this happens.
below my configuration:
add name=vlan_trunk vlan-filtering=yes
set [ find default-name=ether1 ] disable-running-check=no
set [ find default-name=ether2 ] disable-running-check=no
set [ find default-name=ether3 ] disable-running-check=no
set [ find default-name=ether4 ] disable-running-check=no
set [ find default-name=ether5 ] disable-running-check=no
/interface vlan
add interface=vlan_trunk name=data_vlan vlan-id=50
add interface=vlan_trunk name=domotica_vlan vlan-id=200
add interface=vlan_trunk name=guest_vlan vlan-id=25
add interface=vlan_trunk name=iot_vlan vlan-id=100
add interface=vlan_trunk name=mgmt_vlan vlan-id=99
add interface=vlan_trunk name=server_vlan vlan-id=150
add name=dhcp_pool0 ranges=10.0.25.2-10.0.25.254
add name=dhcp_pool1 ranges=10.0.50.2-10.0.50.254
add name=dhcp_pool2 ranges=10.0.99.2-10.0.99.254
add name=dhcp_pool3 ranges=10.0.100.2-10.0.100.254
add address-pool=dhcp_pool0 disabled=no interface=guest_vlan name=dhcp1
add address-pool=dhcp_pool1 disabled=no interface=data_vlan name=dhcp2
add address-pool=dhcp_pool2 disabled=no interface=mgmt_vlan name=dhcp3
add address-pool=dhcp_pool3 disabled=no interface=iot_vlan name=dhcp4
add bridge=vlan_trunk interface=ether2
add bridge=vlan_trunk interface=ether3
add bridge=vlan_trunk interface=ether4
add bridge=vlan_trunk interface=ether5
/interface bridge vlan
add bridge=vlan_trunk tagged=vlan_trunk,ether2,ether3,ether4,ether5 vlan-ids=25
add bridge=vlan_trunk tagged=ether2,ether3,ether4,ether5,vlan_trunk vlan-ids=50
add bridge=vlan_trunk tagged=vlan_trunk untagged=ether2,ether3,ether4,ether5 vlan-ids=99
add bridge=vlan_trunk tagged=ether2,ether3,ether4,ether5,vlan_trunk vlan-ids=100
add bridge=vlan_trunk tagged=ether2,ether3,ether4,ether5,vlan_trunk vlan-ids=150
add bridge=vlan_trunk tagged=ether2,ether3,ether4,ether5,vlan_trunk vlan-ids=200
add address=10.0.25.1/24 interface=guest_vlan network=10.0.25.0
add address=10.0.50.1/24 interface=data_vlan network=10.0.50.0
add address=10.0.99.1/24 interface=mgmt_vlan network=10.0.99.0
add address=10.0.100.1/24 interface=iot_vlan network=10.0.100.0
add address=10.0.150.1/24 interface=server_vlan network=10.0.150.0
add address=10.0.200.1/30 interface=domotica_vlan network=10.0.200.0
/ip dhcp-client
add disabled=no interface=ether1
add address=10.0.25.0/24 dns-server=10.0.25.1 gateway=10.0.25.1
add address=10.0.50.0/24 gateway=10.0.50.1
add address=10.0.99.0/24 dns-server=10.0.99.1 gateway=10.0.99.1
add address=10.0.100.0/24 dns-server=10.0.100.1 gateway=10.0.100.1
set allow-remote-requests=yes
add action=masquerade chain=srcnat comment="default NAT masquarade"
any suggestions/tips?
Thanks in advance!
The PVID for untagged traffic is set to the default of 1, for your setup it should be 99
add bridge=vlan_trunk interface=ether2 pvid=99
add bridge=vlan_trunk interface=ether3 pvid=99
add bridge=vlan_trunk interface=ether4 pvid=99
add bridge=vlan_trunk interface=ether5 pvid=99
You can also omit the untagged VLAN membership as this is dynamically inherited from the bridge ports
Thanks for the reply! Should the bridge itself also have pvid 99 or do I leave that on the default of pvid 1?
Leave it as 1, the tagged management traffic is unencapsulated by your mgmt_vlan VLAN interface for access by the CPU.
